Suspension Ask all of your general suspension questions here!
Which springs?
Old Mar 12, 2012 | 10:04 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Default Which springs?
So I am looking to lower my car alittle but still keep the ride as smooth as possible (yes, I know 1. its a Mustang and 2. lowering doesnt improve ride quality). I was looking at either "B", "C", or UPR springs. I just ordered MM CC plates, and new spring isolaters from AM.
Thanks in advance Jazzer (the resident suspension guru), and those others who respond.
Matthew
Old Mar 13, 2012 | 08:20 PM
Matt's 95 Stang
Resident Ginger
Forgive me as I did forget the inform you all that the car is a DD that does not see track time, if anything it is red to red light fun, or alittle mountain driving.
Thanks,
Matthew
Old Mar 13, 2012 | 08:42 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
I recommend you do two things, when it comes to lowering your car...
1. pick out a lowering kit, that has properly matches spings/dampers, as the easiest way to get it right
2. Don't drop more than 1.5", to avoid geometry issues presented with a farther drop in ride height.
You already have FLSFC's and that would otherwise be #1 on my list of pre-S197 cars. A rear sway bar is generally beneficial, but side note here.... what was the reason you purchased it and specifically which bar is it? Typically, one goes a bit heavier to address some of the understeer designed into the Mustang. This is almost always a good thing, but may not be ideal with a new spring/damper set-up.
What say you?
Jazzer
Old Mar 14, 2012 | 10:11 AM
Matt's 95 Stang
Resident Ginger
What say you?
Jazzer
What say I? Well I bought the FLSFC's on your suggestion and to be honest did not feel any big diffrence but that is neither here nor there. I have a rear sway off a 89 Fox GT and did that to replace the cheap hollow V6 one mine came with. When I replaced the sway I did feel a big diffence with handeling, more important cornering.
Now good Sir, what say you?
Matthew
Old Mar 14, 2012 | 10:21 AM
Jazzer The Cat
Retired Moderator
He he
The FLSFC's will show their worth both in harder cornering and over time, by reducing squeaks and rattles.
The sway bar is a nice upgrade for the V6, as Ford did not install one on them.
that just leaves a lowering kit and your thoughts on a budget and that pesky ULTIMATE goal thing again
Old Mar 14, 2012 | 03:39 PM
Matt's 95 Stang
Resident Ginger
Oh you and your "ultimate goals" question haha. Again the car is a DD with very little racing, no track time (and probably never will), goals are a nice looking DD with not to harsh of a ride. Looking at less than 200-250 for springs. Upper/ lower CA's will be upgraded after I fix a few more things. And I'm not looking to do coilovers as they are just to expensive for me.
Matthew
Old Mar 14, 2012 | 04:01 PM
SteedaBrandon's Avatar
SteedaBrandon
Former Sponsor
Matthew
Our sport springs sound like they are exactly what you are looking for (lowers it 1-1 1/4", great ride quality, handles better), plus they are made in the USA and are ISO 9001:2008 certified (quality control certification). Let me know if I can get you a set of those.
Old Mar 14, 2012 | 07:33 PM
Jazzer The Cat
Retired Moderator
"... Upper/ lower CA's will be upgraded after I fix a few more things. And I'm not looking to do coilovers as they are just to expensive for me.
Matthew
I would NOT recommend a set of upper control arms for you
For your described needs, they OEM ones are fine. The problem with a new set of UCA's is one of two things. The Mustang 4-link suspension is a bind-fest or "quadra-bind" as it is commonly referred, and there are two fundamental types of UCA's on the market. The first is a solid poly/poly bushed arm that is BEYOND horrible to install on a DD ride. It will compound the already inherant bind by about 10 fold and either the arms or your torque boxes will eventually fail. For any non-believers:
The alternative, is a spherical bushed UCA, but will introduce LARGE amounts of NVH and don't see you benefiting from a set of those. Besides, due to the funky motion in which the quadra-bind moves, even a spherica bushed UCA may pose some issues on the extreme end of articulation.
LCA's..... good idea, but strongly recommend you go with a set of spherical/poly bushed ones. This, combined with removal of the quad-shocks, can improve your cornering experience quite a bit.
I would stop at this point, as you would need to make a sugnificant jump in cost and NVH to go the next step in corner-carving. New LCA's, along with some properly matched springs/dampers to go with your existing FLSFC's will make your car handle/ride quite well.
Jazzer says you will be happy my son
Old Mar 14, 2012 | 07:47 PM
Matt's 95 Stang
Resident Ginger
Oh Jazzer you are a funny man. Yes I have read your "Official Suspension Guide" before and let me say "I am not worthy" . haha.
What are your opinions of Steeda's springs? Better, worst than UPR springs?
Thanks,
Matthew
Old Mar 14, 2012 | 08:12 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
Jedi Master Jazzer pic is HYSTERICAL!!!
I've had all of the springs listed in this thread, and I like them all. Of course, I want you to buy the UPR springs, and they do ride pretty nicely since they have a little bit of a progressive rate to them, but the B springs probably have the softest rate. At least that's how they feel from the seat of the pants.
I'm riding on the UPR springs on my daily driver and I'm very happy with them.
http://www.uprproducts.com/mustang-s...-front-94.html
