which adjustable coilovers go the lowest?
To answer your first question air goes the lowest. You second answer KW v3's. I have personally been in cars with v3's, d2's and m/m c/o. So while my opinion is biased it is biased because I did all the same research and that's what I concluded and believe I made the right choice (at least for my needs). Call Sam Strano if you're unsure. Great guy
Fact is 98% of "mustang guys" go with lowering springs and of the remaining 2% 1/2 of them are in the mindset you NEED 3-5k coilovers. Well that isnt true. If you are a race team, have money to throw at your car or are a hardcore track guy then sure KW or some high end brands might be the ticket but if you want street, semi-low and keep your wallet in tact there are others.
From my experience on mustangs, 240's, hondas and a few other cars
D2-ok but not a lot of support and sometimes will rust. Also if something breaks kinda hard to get spare parts. I havent owned these but friends have.
Kw-great have gotten way better over the years they used to corrode and the collars would get stuck. Also haven't owned these but friends have. These have gotten super popular over the years.
Megan/BC- these are suppose to be the same thing. Owned both. The megans I had on my car (240sx) for 4 years. It was a track car but the car was pummeled every time I drove it and I even had a few very hard hits and coilovers were fine. Megans worked great never had an issue really surprised honestly.
BC used these on my 2011 so far (6months in) so good. I would recommend upgrading to a slightly stiffer spring. I believe they come with 5k/6k i went to 6/8 i think i wish i would have gone slightly stiffer but i track my car a bit and its full weight however trade off on the street would be a slightly harsher ride. I lowered my car a decent amount, about 3.5 inches and thus far ride isnt too bad, it handles way better, and the coilovers have had no issues.
For the money I would do them again. TThe downfall of being kinda low is the dumb exhaust hits the panhard bar support on big bumps. Doesn't hurt anything but is annoying. I personally wouldnt go any lower than where I am at. I also have adjustable links (lower, and upper) and sway bars all around. the links are a must
so for reference the car
are you running stock exhaust?
i know the links are a must im just trying to decide if i want to go the coilover route or if i want to go sportlines or lowest spring and use the money i would save for power...
