Bags or Coil overs
Bag or Coil overs.
aleemassacre, I definitely favor the coil overs. I favor Strange suspension products, but there is a multitude of others out there. Check with American Muscle.
Also, if lowering the car, I would strongly suggest installing a adjustable upper control arm, and adjustable lower control arms. The upper is very necessary because when lowering your car you need to be able to set the correct "pinion angle." Also, you MIGHT need a lower control arm relocation kit so the wider tires don't rub. Now to the REAR tires. I run Michelin Pilot Super Sport 285/40R19,103y, on 19x10 rims. This is a pricy tire, but great traction on those "street" hole shots. At the track I favor the Nitto NT05. I would use a Nitto NT05R but Nitto doesn't make that tire in a 19 inch rim yet. By the way, nice looking ride.
