Suspension Ask all of your general suspension questions here!
K member
Old Jun 16, 2024 | 08:20 PM
wi717's Avatar
wi717
Default K member
Havent had a Mustang for years but decided to jump back in the Mustang world again. I have a 1984 Mustang with build 302, the previous owner install a new k member, coilovers, caster plates, the issue Im having is the tires are to far front, I checked and the bolts on the k member is all the way back, I read several pages about this being an issue on certain k members, so what's the fix? I really dont want to cut the fender,. Would adjustable A arms work? Thank you
Old Jun 17, 2024 | 08:30 AM
proeagles's Avatar
proeagles
The geometry of the K member is obviously off. Seems the logical simplest fix is to move the K member back by elongating the hole or drilling new holes. Once proper alignment is achieved weld the K member in place. I'm not sure adjustable A arms would move the axle back as their purpose is to locate and control up and down movement. Perhaps someone else will have a better idea. Good luck.
Old Jun 17, 2024 | 09:55 AM
drhoward's Avatar
drhoward
Penis Mod Erator
Pretty much every k-member for fox bodies move the control arms forward I doubt that there is anything wrong with it. Maximum sells an a-arm that moves them back to the stock position but you need to run them with coilovers (might be a pain if you don't have them). There may be others out there that do the same thing though
*Edit
Just reread your post about your coilovers, you should be good with the maximum control arms
Old Jun 17, 2024 | 12:23 PM
proeagles's Avatar
proeagles
I agree with drhoward above.
Old Jun 17, 2024 | 04:33 PM
wi717's Avatar
wi717
Well the good thing is I already have coilovers installed, I just didnt want to drop 400.00 on adjustable a arms and it not work.
Old Jun 18, 2024 | 07:57 AM
drhoward's Avatar
drhoward
Penis Mod Erator
The maximum motorsports ones aren't cheap (but they're the best you can get - I have them on my car). Looks like the adjustable ones are from BMR? They're about the same price, I'd go with the maximum ones personally between the two, not sure how much it really matters though.
Old Jul 12, 2024 | 02:04 PM
wi717's Avatar
wi717
Default THX
Id like to thank everyone that chimed in, I went with the MM reversed offset a arms and worked out perfect
Old Jul 12, 2024 | 02:10 PM
proeagles's Avatar
proeagles
Good deal. Thanks for letting us know.
08blackoutstang
Washington Regional Chapter
Jun 2, 2010 10:15 AM
Dull_Machete
Sep 21, 2009 03:30 PM
ttracing98
Apr 7, 2007 02:26 AM
ttracing98
Apr 7, 2007 02:22 AM
sstang
Oct 1, 2006 08:59 PM
