SVO Forum
svo mustang electronic problems
Old Jul 15, 2006 | 02:14 PM
ridearea51's Avatar
ridearea51
Default svo mustang electronic problems
does anyone have any ideas of why an svo i'm looking at surges from 300 to 1200 rpms when its cold. and if u don't help it out on the gas a little bit it dies. i'm thinking its some sensor but am just not sure which one it might be. otherwise it runs great once u get it warmed up. thanks
Old Jul 15, 2006 | 06:27 PM
DRAGPAK's Avatar
DRAGPAK
Default RE: svo mustang electronic problems
Check your tps voltage make sure its set right.
Old Jul 16, 2006 | 10:50 PM
ridearea51's Avatar
ridearea51
thanks a bunch do u have any other ideas
Old Jul 17, 2006 | 02:11 AM
Jugador's Avatar
Jugador
it could be the idle air control, but i think only the tps would cause it to surge that bad
Old Aug 28, 2006 | 01:24 PM
bluecorners's Avatar
bluecorners
What year is the car? My understanding is that the TPS does not need adjusting in the newer years, the computer does an inquiry on start up and makes what ever it sees "zero". The old 5.0 had to be set. Anybody know?
Old Aug 31, 2006 | 07:38 PM
plazma's Avatar
plazma
If it's an svo then it's not one the doesn't require adjustment. If your idle surges that much then check the tps voltage as recommended. Then pull out the iac and clean it out. After that try checking your timing and see where it at.
Could be several things but those are the most common ones I know.
Old Feb 21, 2007 | 01:27 AM
safado's Avatar
safado
eec test it...
Old Mar 13, 2007 | 11:24 PM
Chemical_Excuse's Avatar
Chemical_Excuse
i'm having this same problem on an 84 svo i just bought...will not even run on its own when it's cold unless you sit and car and give it gas...then surges until is really warm...
Old Mar 14, 2007 | 11:14 AM
sleeper_inc's Avatar
sleeper_inc
Check your TPS, more than likely its out or dead, clean you IAC and check your timing. If all that is done and it keeps doing that, might want to check your vaccum lines
FD725
Aug 23, 2015 06:43 AM
inyadreems
Aug 21, 2015 09:10 AM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
daytooday
Aug 11, 2015 09:22 AM
