SVO Forum
2.3L Engine Question
Old Nov 29, 2006 | 12:55 AM
TClear4's Avatar
TClear4
Default 2.3L Engine Question
I'm thinking of getting an svo with a bad 2.3l engine. Can i replace it with any Ford 2.3L or is the svo engine different in some regard? Can I use merkur, thunderbird turbo engine?
Old Dec 1, 2006 | 02:45 PM
TRBOPWR's Avatar
TRBOPWR
Default RE: 2.3L Engine Question
They are all basically the same engine, but I believe that you would have to use the original wiring harness if you do a swap.
Old Dec 1, 2006 | 03:27 PM
83beast's Avatar
83beast
the SVO/TurboCoupe/XR4Ti/Cougar Turbo all had the SVO motor. some without intercooler, some with more boost, some with different ECU tuning, but the same longblock and hardware. the diff between a non-SVO (turbo or not) 2.3 and an SVO 2.3 is mainly the head. the SVO motor had a special hi-perf head specifically for that motor. other than that, im pretty sure the rest is the same. and yes, the SVO and T-Coupes had the intercoolers so the ECU and wiring is diff than the others. the T-Coupe had a better intercooler, but the ECUs were pretty much the same, with the later T-Coupes having the best ECUs.
Old Feb 21, 2007 | 01:23 AM
safado's Avatar
safado
The xr4ti and turbo coupe engines are the same as the SVO, minor deals with the oil pan and stuff..like the oil level sensor...The PCMs and some harness pins are different.. The later turbo coupes are "considered" to be the best PCMs.... But they are not plug and play.. certain pins are different and the later Birds had an additional IAT...
jlopret
2.3L Eco-Boost Tech
Nov 19, 2015 10:32 AM
ShaneB26154
Aug 28, 2015 04:47 PM
classic69FB
Aug 12, 2015 11:58 PM
HIS S-197
Aug 10, 2015 05:47 PM
