SVO Forum
boost issues?
Old Jul 16, 2009 | 05:16 PM
cyote's Avatar
cyote
Default boost issues?
Hey there, I am new to these cars and I have a 1985 svo. The problem with the car is that I installed a dual stage boost controller from Turbo XS to turn up the boost, but the thing will only hit 15 p.s.i. max. I noticed that it will first build to 18 p.s.i. for about a second, then level off to 15. Any sugestions would be great!
Old Jul 17, 2009 | 09:01 AM
sleeper_inc's Avatar
sleeper_inc
You don't need a dual boost control, but make sure its seeing boost from the turbo and the other line is going to the wastegatte and not flowing through the actuator that comes stock on your SVO to limit boost
Old Jul 17, 2009 | 10:41 AM
cyote's Avatar
cyote
I took the wastegate hose and hooked it up directly to the bcs. The other hose I took and plugged it into the the turbo. Now I am getting good boost, but it will spike, and then level down to 18 lbs. When on boost it will go up to 20-22 lbs. then drop down to 18. What could be causing that?
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Sep 30, 2015 10:13 AM
