how many svt owners?
Still lovin it! I've got a project schedule in place, just need to start checking things off the list!
-hydraulic throw out bearing and clutch/flywheel
-Re-build brake system & install steel brake lines
-springs,c/c plates,x2 balljoints,bumpsteer kit, coil over front & shocks rear, sub-frame connectors,& anything else I can do to stiffen up the chassis..
-FRPP 4.10 gears & dyno tune.
-MAC ProChamber catted mid-pipe to join the Spintech 9000's on there now
-Wheels/Tires~ choice changes daily. AM Hopster, Chicane's, ???
*Not enough time in a day, not enough money to be made, all the same excuses need to disappear & I need to start making things happen!!!!
Thanks- Robb
Thank You-
Thanks- Robb
Thanks- Robb
Right now I'm doing some minor interior mods. Got me a new instrument bezel and lens, odometer gears, custom SVT decal for above RPM's, warm white LED's for gauges and AC controls, and I'm painting the steering wheel flat black using adhesive promoter & black dye spray. A set of bullitt pedals too.. Good Times!!
No- But, never say never! I will have fun with it geared and dyno tuned. I'm lucky enough to have a great tuner here locally. i'm really looking forward to having a great feeling transmission with a hydraulic throw out bearing and possibly a twin disk McLeod RST clutch kit.
I have my design mapped out in my head as far as components & their location piped in. These will again be piped into Spintech 9000 mufflers.
Should sound pretty raw & aggressive under heavy throttle sounding like thunder. I am impatiently waiting to start install and welding myself this time.
*A clutch kit is needed ASAP now as it is most likely original and slipping. McLeod will be going in. MM cable and quadrant/adjuster to pair up.
GREAT CARS HERE- Always giving me inspiration
