SVT Forums
03 pully
Old May 18, 2004 | 02:43 AM
nemethjames1's Avatar
nemethjames1
Default 03 pully
just bought an 03svt cobra and i want to change the pully, how many psi is it useing stock? the gauge only goes to 10psi... should i go to about 20 or would that be overdueing it? any thoughts? thanks
Old May 18, 2004 | 03:19 AM
fuzi0nz's Avatar
fuzi0nz
Default RE: 03 pully
03 uses 8psi stock. boosting to 20psi would be WAY too much unless the rest of your car was modded off the wazoo
Old May 19, 2004 | 12:07 AM
nemethjames1
well on my gauge cluster, it has a gauge, and it sais 0 - 10psi, and when i open it up it tacks all the way to 10... but i just want a smaller pully on there so i can boost it, any thoughts on how much psi i should go to? and how long does it take to change out a pully? any ideas? thanks guys
Old May 19, 2004 | 02:02 PM
callmecobra's Avatar
callmecobra
you cant get 20 psi out of your stock blower...the engine could handle 20psi from an aftermarket blower tho, say like procharger or kenne bell
Old Jun 10, 2004 | 02:19 PM
RAZRS EDGE's Avatar
RAZRS EDGE
New to blown motors. What will be the effects, if any, if you incrcease the boost to say about 12psi on an 04 Cobra? What would need to be done except tuning?
Old Jun 10, 2004 | 02:24 PM
callmecobra
no effects, other than hp increase. i recomend getting the most psi you can out of the stock eaton blower tho, you can get more than 12psi. as far as tuning goes, wait until all bpu mods are done.
Old Jun 10, 2004 | 02:41 PM
RAZRS EDGE's Avatar
RAZRS EDGE
ok cool. thanks for the message too. i responded.
Old Jun 14, 2004 | 10:01 PM
IntruderLS1's Avatar
IntruderLS1
I would be VERY careful before you start throwing that much boost into your ride. I've been a broken record tonight, but HOMEWORK, HOMEWORK, HOMEWORK. What is the compression ratio on that car BTW?
ctgreddy
Sep 20, 2015 08:35 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
96mustanggt46
Jan 12, 2004 02:52 AM
VicsGT
Nov 25, 2003 07:07 PM
skatepony
Jul 30, 2003 10:12 PM
