Need Help
Sup guys,
Well i looked called steeda and asked them how much there billet steel flywheels weight and they told me 24lbs. And the aluminum is 12lbs. Now that messed me up. If the steeda billet steel is supposed to be lighter then that means my stock flywheel is like 43lbs or something. Does anyone know how much a stock cobra flywheels weigh in at?
99 cobra
99 cobra
It's probably not as huge a differance as you're thinking. On the drivetrain like that, every pound counts more than you can imagine. If you're going FI though, don't go w/ aluminum. The advertisments make it sound all good, but you don't need those headaches.
Howdy - I also need to replace my clutch, I have an 01 Cobra. Does anybody know if there is a good aftermarket clutch that is as strong or stronger than the stock, but has a lighter or easier engagement. Unfortunately for me my wife drives the car a lot so I can't get a heavier clutch. The car is mostly stock and will remain that way except for chip which I will be doing very soon. Thanks for any suggestions.
