SVT Forums
car is bogging????????
Old Jul 31, 2006 | 09:03 PM
CobraSnake's Avatar
CobraSnake
Default car is bogging????????
i don't understand why, but i cannot get a good launch in my cobra it just seems to bog everytime unless i hold it out to like 4k rpms and then it just will screw my rear end. Occasionally it seems to work fine but i'd say 90% of the time it seems to not want to launch right. I try holding the rpms at about 2k and just let go of the clucth and it bogs. I try to do a normal yet quick take off and it bogs. What could possibly be the problem??????
Old Jul 31, 2006 | 09:10 PM
CobraSnake's Avatar
CobraSnake
Default RE: car is bogging????????
also one more thing i forgot to add was that the car has 11,000 miles on it and the clutch seems fine its not slipping just bogging. Check out my video in my sig too because it kinda bogged there too at the track.
Old Jul 31, 2006 | 09:24 PM
JamesTronix's Avatar
JamesTronix
Traction control on?
Old Jul 31, 2006 | 09:31 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: JamesTronix
nope
Old Jul 31, 2006 | 10:57 PM
7arpad7's Avatar
7arpad7
Saw your vid. Doesn't seem too bad for bone stock. It looked like you had some wheel hop going on there and maybe a little bogging going on. I would suggest that you get it on the dynamometer and hook it up to the computer... there are so many variables that it would be hard to say without really getting all of the info together and then taking some direct course of action. It can really save you a ton of money doing it right and planned out then if you were to just start shooting in the dark trying to fix this problem. You definitely need to look to see if you are getting proper boost out Eaton, that you are getting enough fuel/pressure, and that there is enough spark/proper timing... I have fewer horses to work with and get great a launch due to the rear gearing allowing the motor to "spool up" faster. So there is always that route, but it most likely isn’t the right one for your set up (terminator).
Old Jul 31, 2006 | 11:11 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: 7arpad7
wow thats some good advice, but i don't have enough money right now to get my pulleys and i wasn't planning on putting it on the dyno until i do that. There is no sense it dynoing it now and then just having to do it again later. My car also still has warranty and i've taken it too the dealer about it and they say that it drives fine.
Old Aug 1, 2006 | 12:28 AM
JamesTronix
My car is not the greatest out of the hole either. It tries to bog a little. I think it is the stock 3.55 gears.
Old Aug 1, 2006 | 11:57 AM
CobraSnake's Avatar
CobraSnake
thats what i was thinking, but my cars weird sometimes it drives great. The take off is great switching gears is nice and smooth and the same thing with downshifting. But, sometimes it wants to bog shifting is a little rougher and when i downshift it really goes into the gear and slows down quickly unlike some of the other times where when i downshift it goes into the gear like butter and then start to gradually slow down.
Old Aug 1, 2006 | 01:37 PM
mg01svt's Avatar
mg01svt
Your car looked ok to me in the vid. You are going to bog anytime you do a low rpm clutch dump. Have you tried launching at 4200rpm and slipping the clutch? It is all in the timing of clutch release and throttle application. Your car is running decent times for the mods. Yes, it can do a bit better, but if you want more out of the car then you need to push it a little. Go out and make sure you heat the tires well. Get a good white smoke off the tires for a few seconds. Line up and forget about the tree. Bring the revs up to 4200-4500. Dont be scared, but dont dump it either. When you are ready to launch(this is where the timing comes in) begin a controlled release of the clutch and increased throttle application at the same time. Its kind of difficult to describe. Something you just develope a feel for. Remember make sure you heat the tires well. You will get some violent wheel hop, if you dont melt'em some.
A
Old Aug 1, 2006 | 01:49 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: mg01svt
A
see i really don't mind bogging at the track i'm not really talking about the track. I'm just talking about everyday driving and racing. Like if i'm not paying attention to the light and it turns green and i have to take off quick because of cars behind me getting pissed so i try to do a quick little take off and it bogs its weird. I had this problem in my focus SVT when it was a full tank of gas it would bog off the launch but if it was a 1/2 a tank or less it would drive fine. Turns out it was computer upgrades and i asked about that at the dealership and they said there were none and that the car was fine.
