SVT Forums
2001 Cobra
Old Aug 5, 2006 | 02:12 AM
NonMiAnnoiare23's Avatar
NonMiAnnoiare23
Default 2001 Cobra
This is my second Mustang that I have owned, the first was a 96 GT. I do not like the feel of the clutch on the Cobra, you have to put it to the floor to change gears. In the 96 GT I had, you only had to press a quarter or so down and you could shift, is there a way that I can do it on the Cobra?
Vince
Old Aug 5, 2006 | 12:52 PM
sweet99's Avatar
sweet99
Default RE: 2001 Cobra
It may be adjustable under the dash where the rod from the master comes through the firewall and the clutch pedal linkage connects to it. It should be adjustable there. The master rod should turn after loosening a lock nut to make the change.
Old Aug 10, 2006 | 05:11 PM
zincsvtcobra's Avatar
zincsvtcobra
You could always get an adjustable clutch quadrant and cable to make adjustments without getting under the car. The kits are usually under $120.
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
Sixer4Life
Sep 29, 2015 07:03 PM
Sixer4Life
Sep 28, 2015 07:05 AM
