SVT Forums
12 second 1/4?
Old Sep 5, 2006 | 04:44 PM
Timmy59's Avatar
Timmy59
Default 12 second 1/4?
what will it take to get a 2001 Cobra into the 12's without adding F/I or spray? I wanna go all motor and pull into the 12's...is this possible or will I have to buy an LS1 or be the recipient of an act of god?
Old Sep 5, 2006 | 05:29 PM
zincsvtcobra's Avatar
zincsvtcobra
Default RE: 12 second 1/4?
12's? With the right parts and some driving skills, you could run 11's on motor. Might be a little pricey though. I would get some good wide drag radials, 4.10 or 4.30 gears, the basic bolt-ons, and an aggressive but safe tune. If still not there, get some cams and ported heads. Don't forget that if you plan to spend 3 or 4 grand to run 12's, you could spend that money on a S/C and run 11's. Your motor will be fine as long as you get a proper tune and don't beat her everyday.
Old Sep 5, 2006 | 06:30 PM
Timmy59's Avatar
Timmy59
In the case of a supercharger, would it be more cost effective in terms of power:money ratio to buy an 03 or 04 and mod it...or stick with a 99-01 then buy a larger aftermarket setup?
.... this question has probably already been asnwered a thousand times...I should probably be searching for this info, but I'm at work and I can only hop on here every so often to avoid trouble
thanks for the quick initial reply BTW
Old Sep 5, 2006 | 08:40 PM
michael12203's Avatar
michael12203
i have a 99 with the listed mods below and went 12.9 in 91 degree weather at night at jackson south carolina, i was powershifting like hell but it was worth it just have to rid the car of that wheelhop
Old Sep 6, 2006 | 07:06 PM
Quicktime_GT's Avatar
Quicktime_GT
i'd say some 4.10s.. drag radials... headers/midpipe .. control arms and a 5 grand launch + a little "if it breaks i'll buy a new one" attitude
An older local man took a mach 1 into the 12s with similar mods... figured it'd be similar with you
Old Sep 9, 2006 | 08:48 AM
03COBRA/C5KILLER's Avatar
03COBRA/C5KILLER
I saw a 99 cobra w/ exhaust/intake gears & cams get into the 12's, it's actually not hard to get more hp out of the 32v motor, but I would'nt go s/c if I were you because the 99/01 motor does'nt have forged pistons like the 03/04's do. Nice rims apc! what rim/tire size you run?
Gene K
Oct 21, 2015 11:37 PM
heslekrants
Sep 23, 2015 04:02 PM
MonsterBilly
Sep 20, 2015 06:56 AM
96stang3.8
Sep 10, 2015 06:42 AM
zachary1988
Sep 4, 2015 03:04 PM
