03 boost question
ORIGINAL: Asylum839
How much boost can the stock supercharger and engine handle before I start running into problems? On an 03 cobra
Question about dropping pulley size (sorry for the off topic)
I know in my car there was a lot of mods I needed to do to stay away from knock Retard. Same thing for this model cobra or can you drop with a exhaust mods only?
ORIGINAL: GTPGuy
No, I have a grand prix GTP. Two years from now I'm planning on buying either an 06 GTO or an 04 Cobra. I think if I do go with the GTO, I'll miss the supercharger; that's why I'm leaning toward the Cobra at this point.
ORIGINAL: 03InDisguise
I agree with free *****, anything over 15 psi, and you'll be pumping heat into your engine. Personally, i would stick to around 13-14 just to be safe. Heat=ineffiancy (sry bout spelling =P)
I see about 17-19lbs with a 2.93/6lb lower and ported Eaton. It does drop boost but only down to about 14 and that's after about 4500-5000 RPM. The torque is through the roof too. The difference in boost for me is weather related, here in NC the humidity sucks the life out of the Eaton worse than a ho downtown.
ORIGINAL: Asylum839
If you want to see the relationship of boost to blower rpms, take a look at the Boost Chart on my FAQ page. http://stangshiftergaskets.com/2003_...m#_Toc35092360
jwog666
Dec 27, 2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
