SVT Forums
Throttle body
Old Aug 2, 2004 | 07:03 PM
99 cobra's Avatar
99 cobra
Default Throttle body
Wasup guys,
I have been wanting to change my tb to a bigger size. But i am not sure which i want either the 62mm or the 65mm. I know the 65mm will run through gas alot which is not a problem but i don't want to have any problems with ideling or flooding. Tell me what you guys think.
99 cobra
Old Aug 2, 2004 | 07:27 PM
callmecobra's Avatar
callmecobra
Default RE: Throttle body
def dont get a bbk tb. get the accufab single blade, if you think upgrading the tb is nesecarry.
Old Aug 2, 2004 | 07:29 PM
99 cobra's Avatar
99 cobra
Why whats wrong with a bbk tb. I actually heard people have had problems with accufab staying stuck open. Well tb isn't the only thing. Headers tb and injectors maf all at the same time.
99 cobra
Old Aug 2, 2004 | 07:37 PM
callmecobra
just look at the 2. there is no comparison in air flow.
vs
Old Aug 2, 2004 | 07:41 PM
99 cobra's Avatar
99 cobra
well should i go with the 62mm or the 65mm
99 cobra
Old Aug 2, 2004 | 08:20 PM
callmecobra
ORIGINAL: 99 cobra
99 cobra
neither. single blade or nothing.
Old Aug 2, 2004 | 09:44 PM
99 cobra's Avatar
99 cobra
Have you seen hp jumps from the accufab tb? I see i can choose from either the 70mm or the 75mm. Is that too big? I also see they come with a Plenum? What is that supposed to do? I am new the the throttle body stuff.
99 cobra
Old Aug 2, 2004 | 09:56 PM
callmecobra
ORIGINAL: 99 cobra
99 cobra
i havent seen dyno charts. personally, a tb is a waste of money on a mild NA motor. if i were forced induction and had $ to blow, ide get the single blade. but the single blade will dyno more, if there is any increase at all.
Old Aug 2, 2004 | 10:01 PM
99 cobra's Avatar
99 cobra
sorry i keep replying i seriously don't know much about the tb. So you think if i add headers, injectors, mass air flow sensor and the tb i won't get the gain i would like. With the mass air flow do what size do you think i should get?
What mustang do you have?
99 cobra
Old Aug 2, 2004 | 10:08 PM
callmecobra
i had a supercharged 96 cobra, with stock maf and stock tb. and with only 8psi from a vortech, i was doing 460rwhp. personally, you need to focus on full exhaust first. long tubes, off road mid pipe, magnapack exhaust. you dont need injectors, and maf and tb should be the last thing you do.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
