SVT Forums
Suggestions on Upgrades
Old Oct 27, 2006 | 05:18 PM
Crimson Fox's Avatar
Crimson Fox
Default Suggestions on Upgrades
I am about to put in the upgrades. Check out this list and let me know if you see anything that my conflict. Thanks.
BBK LP Headers
Short H-pipe w/cats (for long pipe headers)
Flowmaster Am Thunder Cat-back w/40 series
Steeda Tri-Ax Shifter
H&R Sport Spring set for Convertible
MM Urethane IRS rear spring isolators
MM Urethane front spring isolators
Billetflow IRS Brace
Steeda Underdrive Pulleys
Motive 4.10 Gears
JLT Performance CAI
SPEC Stage 1 Clutch Kit
SPEC Billet Aluminum Flywheel
Diablo Sport Tuner
Old Nov 11, 2006 | 10:10 PM
mblgjr's Avatar
mblgjr
Default RE: Suggestions on Upgrades
Might want to consider some PHP rear toe rods and using an SCT tune. The tune part depends on if you intend on dynoing locally or doing mail order.
Also, I'd suggest getting the MM IRS carriage bushings while you're there. They REALLY help a lot with wheel hop and keeping the rear planted.
Old Nov 11, 2006 | 11:28 PM
burning the tiers's Avatar
burning the tiers
if i was you i would go with the magnaflows insted of the flowmasters. magnaflows sound so much better
Old Nov 13, 2006 | 12:17 PM
AllVenom's Avatar
AllVenom
Are you sure you only want to go with a Spec 1? I'd consider something like a 3.
Old Nov 13, 2006 | 02:47 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: burning the tiers
and are stainless steel. Flowmasters will rust.
Old Nov 14, 2006 | 12:41 AM
hulian's Avatar
hulian
i really like my magnaflow, it has a great sound and just that little but of a pop when you let out on it.
Old Nov 14, 2006 | 10:44 PM
Crimson Fox
I considered the Magnaflow. If the flowmaster doesn't work out, maybe I will sell it and get a magnaflow instead.
Making the rear end more solid is the next project. These parts are just the beginning.
I plan to get sub-frame connectors, bushings, etc.
Ran out of money this round, that's all...
-Nicholas
PaulH2
20
Jan 31, 2016 09:48 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
