SVT Forums
Ok Big problem. Please answer if you know.
Old Nov 2, 2006 | 11:53 AM
sirlammy21's Avatar
sirlammy21
Default Ok Big problem. Please answer if you know.
Ok heres the deal. I have an 01 cobra with all the mods listed below. i have been running about 13.5 for a while then i hit 13.2 and then on my 2nd to last run last week i hit 12.8 at 106. But the run after that when i took off at the line i ended up snapping my axle and osmehting else in the rear. I was getting ready to buy a supercharger but i realized if the rear cant handle the horsepower now it will never be able to handle it with a s/c. So what can i do to my rear to make it stronger? Dont forget it is an 01 cobra which means it has the IRS. I ahve the cobra r IRS brace, aftermarket bushings and springs. But i need it alot stronger. i ahve about 1000 to put into it maybe more if i wait a little while. what can i do ive heard i could put in a solid rear axle but that would cost liek 1000 just for that before i can even beef that up. So any suggestions?
Old Nov 2, 2006 | 01:28 PM
spray175's Avatar
spray175
Default RE: Ok Big problem. Please answer if you know.
Having an IRS means you dont have an axle. You can buy level 5 halfshafts which will be the best investment in the IRS. They run 1300-1500. Get a billetflow IRS brace. Lowering springs and bushings will help to. It is cheaper to buy a solid rear, thats why you see alot of people doing it. It gets expensive.
Old Nov 2, 2006 | 02:05 PM
MuscleOwnzRice's Avatar
MuscleOwnzRice
dont get rid of the IRS, the irs can be VERY beneficial and alot smarter if your driving on open road as a DD also. IRS can be beefed up enough to handle anything, in the november issue of Modified Mustangs they have a whole article on it and irs is recommended to keep UNLESS your going all out drag car
Old Nov 2, 2006 | 06:15 PM
zincsvtcobra's Avatar
zincsvtcobra
+1 Keep it!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
guitarman376
Sep 30, 2015 05:54 PM
69Volunteer
Sep 30, 2015 10:39 AM
UrS4
Sep 30, 2015 10:13 AM
