SVT Forums
building a cobra motor
Old Nov 23, 2006 | 07:09 PM
silverstang1996's Avatar
silverstang1996
Default building a cobra motor
i'm interested in building a 4v motor from the block up, what would be some suggestions on best way to pull highest hp/tq numbers with a N/A 4v?
Old Nov 23, 2006 | 07:14 PM
ponysnake99's Avatar
ponysnake99
Default RE: building a cobra motor
High compression and a good set of ported/polished heads...i heard you can put navigator heads on your car but its for minimal gains...its already a better breathing motor, just up the compression (forged and all for strength), an agressive cam and some of the basic valvetrain work and you'll be golden
Old Nov 24, 2006 | 12:02 PM
David_K's Avatar
David_K
big bore stroker motor. you can make over 400whp good luck trying to get those number in a n/a 4.6L
dont do a set of ported or polished heads. stock 03 cobra heads will outflow ported 01 heads.
Old Nov 24, 2006 | 01:01 PM
jacrockett's Avatar
jacrockett
If you're going to spend that much $$$, why do you want to be n/a?
The most cost effective way to convert a GT to 4v is to buy a crate motor:
http://dagostinoracing.com/index.php...oducts_id=9079
I've seen 4v crate motors available with ported heads and a Whipple blower for $15k. SHM sells a Cobra crate motor with a KB s/c for $17.5k.
Old Nov 24, 2006 | 01:05 PM
michael12203's Avatar
michael12203
the mach 1 heads are very good and you can have them ported and polished, will it stroked to 5.0 and higher comp, and good heads and cam you can easily have 400 hp
Old Nov 24, 2006 | 03:24 PM
David_K's Avatar
David_K
mach 1 heads are the exact same as 99 heads. they dont flow well. 03 cobra heads will outflow ported mach 1 heads
Old Nov 25, 2006 | 03:19 AM
ponysnake99
I got a comparison somewhere that says the B series heads (96-98) will outflow the others...just bolt up a set of Ford GT heads and call it good[8D]
Old Nov 25, 2006 | 11:56 AM
michael12203
they arre not the same as the mach 1 heads look them up, those and the 03 heads are different from the 99 cobra heads i guarantee! let me find it somewhere
Nov 10, 2015 11:39 AM
rksnow1
Sep 14, 2015 08:46 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
jaiidutch
Sep 14, 2015 10:29 AM
Sparks_88
Sep 8, 2015 01:06 PM
