SVT Forums
Does the FIPK really work?
Old Sep 12, 2004 | 04:17 PM
callmecobra's Avatar
callmecobra
Default RE: Does the FIPK really work?
an intake pipe isnt a power adder, it should be in the performance or svt section.
Old Sep 13, 2004 | 10:52 PM
jefflesh's Avatar
jefflesh
Nomo,
Thanks for your reply and you attempt at answering my question. However, I think don't think I agree with you. K&N state on their web site that their FIPK adds 30.2 HP over the stock filter, if this is true than an intake pipe is a power adding devise. Additionally, if you think of the engine as a whole the intake is just as important as an exhaust system. People change the exhaust to have better flow thus increasing HP. I would think one could think of an intake pipe in the same way. If we did not gain power than why change the pipe?
Thanks for your time.
Sincerely,
Jeff
Old Sep 14, 2004 | 06:24 PM
Ducks03cobra's Avatar
Ducks03cobra
Jeff, im pretty sure that Nomocobra is talking about extreme power adders like a supercharger, turbo, nitrous. A air intake is considered to be just a "bolt on part" along with exhaust. If i am wrong someone please correct me so i will know myself.
Old Sep 22, 2004 | 01:50 PM
jefflesh's Avatar
jefflesh
Ducks,
Thanks for your reply. I understand that the nitrous, turbos and supercharger all add a lot of power to a vehicle. If there were just a room for those items I would not have included the FIPK in that room. That being said, the FIPK is equally important as exhaust. As a matter of fact, the HP gain in my cat-back system is less than the gain I received from the FIPK intake. So I bring the question up again, how is an intake system not considered a performance part if it actually increases HP and torque?
Anyways, I picked up my FIPK yesterday and from what I could tell, I did gain more HP. I also noticed that I am getting more boost, so the supercharger must be breathing a little better. I have to take my car into the shop to have some warranty work done to it, I would assume that I have to put the factory intake system back on the vehicle before I take it in? I am sure that the FIPK would void my warranty.
Thanks everyone for your time.
Sincerely,
Jeff
Old Sep 22, 2004 | 04:14 PM
rtm's Avatar
rtm
What kind of warranty work?
If it is any way related to the K&N and your Dealer is a hard a$$, I would say to remove it.
By the way, I have talked to 3 SVT dealers in my area who said that they would only consider a pulley and tune to be a deciding factor.
The dealer that I take my car to knows that I have the mods listed. He said that they would still work with me, but if I had any work that could relate to the mod that they would have to charge me.
I believe that is fair.
Todd
Old Sep 22, 2004 | 05:11 PM
jefflesh's Avatar
jefflesh
rtm,
Thanks for the reply.
There are currently 3 things which need to be fixed.
1) There is a vacuum hose which is split at one end.
2) The front corner of the trunk rubs the body when opening the trunk, this has actually rubbed off the paint.
3) The rubber on the peddels are coming off.
Nothing to do with the intake or exhaust of the car. I guess I was thinking more down the road. For example, if something were to happen to the blower I wouldn't want the dealer to look back and say that the FIPK caused the problem with the blower.
Thanks again for the reply.
Sincerely,
Jeff
Old Sep 23, 2004 | 09:19 AM
rtm's Avatar
rtm
Jeff,
Yeah, I can see your point. I guess it really comes down to what you think is the best. If you have any doubts at all, I would just remove it. It will not take that long anyway.
I would also suggest trying to get "hooked up". The small Mustang club that I am a member of has a few 03-04 Cobras that are modded. First thing I did was ask where they took their cars for any service work. Now I go to the place that I mentioned in the other post that knows my mods and said they would be fair to me.
Good Luck!
Todd
Old Sep 23, 2004 | 09:52 AM
jefflesh's Avatar
jefflesh
Rtm,
ORIGINAL: rtm
ORIGINAL: DnB
rtm,
Thanks for the heads up on the drilling. So you are saying that it might not be necessary?
Dave
I have talked to people who have done it both ways. Some are **** about drilling holes in a new car. The hole is drilled in a corner of the fenderwell. The heat shield attaches to it. The shield also attaches to a hole already there, plus a bracket that is mounted piggyback on a radiator support I believe.
I did not drill the hole as I thought the other two gave it plenty of support.
Just about any CAI you choose will probably require drilling a hole.
Todd
In this reply you stated that you have attached your FIPK in 2 locations, is this true? Mine only had the ability to attach in 2 locations, 1 being the radiator and the other being the drilled hole. As I said, I am not into drilling my new car, leads to rust down the line. But, I think I need more than 1 attachment, so I was thinking on using double sided tape or something to hold the bracket which requires drilling in place of drilling.
Let me know if yours has 3 attachemnt locations, if possible, could you take a picture and post it on here, I would like to see what it looks like. I will do the same for mine later today, and we can see what the difference is.
Thanks again.
Sincerely,
Jeff
Old Sep 23, 2004 | 11:16 AM
rtm's Avatar
rtm
Hey Jeff,
I'm sorry. You are completely right. I pulled out my instructions and they were as you said. I would post a pic but I currently have my car in the shop. I had it wrong. I am only using the one support and it seems to be doing fine.
That's a good idea about the tape though. [sm=smiley20.gif] I am going to look at that.
The reason my car is in the shop is I developed a slight creaking noise in the steering rack that can be heard when turning the wheels to the right. It turns out that there is a TSB on it. They are replacing some bushings and sleeves. It does not hurt the car and you can barely hear it. But I want things right.
I hope to have it back by this weekend.
Todd
Old Sep 23, 2004 | 12:57 PM
jefflesh's Avatar
jefflesh
Todd,
Thanks for your e-mail. I noticed today that I am getting a air pressure release from somewhere when the A/C compressor comes on. It might just be the sound of the compressor but it really sounds like an air leak for a second like a "pppsssttt". Also, after I out my exhaust on I notice a little pop sound when I start the car.
The TSB you are talking about is that Technical Service Bulletin? If it is, I would think I would have to have my car checked. Any other things you found on your car that I should pay attention to?
Thanks again for your time.
Sincerely,
Jeff
