SVT Forums
BRAKE PROBLEMS-MORE INFO
Old Jan 7, 2007 | 12:07 AM
RED COBRA's Avatar
RED COBRA
Default BRAKE PROBLEMS-MORE INFO
2000 COBRA R, CAR WILL ROLL WITH MOTOR OFF, WHEN MOTOR STARTS WILL NO PRESSURE ON BRAKE PEDAL CAR CAN NOT
BE MOVED. THE CAR FEELS LIKE THE BRAKES ARE BEING APPLIED WHILE DRIVING
Old Jan 7, 2007 | 04:34 PM
Lizardbreath's Avatar
Lizardbreath
Default RE: BRAKE PROBLEMS-MORE INFO
BAD BRAKE CALIPERS OKAY YOU ALREADY MADE A THREAD ABOUT THIS BEFORE.
Old Jan 7, 2007 | 04:47 PM
RED COBRA's Avatar
RED COBRA
thats not the problem either. I'm new to these forums that's why I started a new post instead of the reply.
Old Jan 8, 2007 | 02:01 PM
MuscleOwnzRice's Avatar
MuscleOwnzRice
alrighty, try your pistons within the calipers, did you do that?there isnt much else to it
Old Jan 10, 2007 | 10:17 AM
hulian's Avatar
hulian
it should"t be the calipers ,once they go bad they stay bad and it is not very likely to have two bad calipers at the same time. actually it almost never happens at th same time. If it is only when you turn the car on i would say you power brake booster is causeing the brakes to engage and stick. another thought would be the antilock brake system. may need to be bled, that could cause the brakes to lock when the car is turned on, or keep them locked even when power was shut off. have you done anything to the brakes since it started happening??
Matt's 95 Stang
Oct 5, 2015 07:16 AM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
