SVT Forums
03 cobra
Old Feb 9, 2007 | 11:16 PM
rfbowers's Avatar
rfbowers
Default 03 cobra
I bought an 03 cobra recently before i bought itthe previous ownerhad engine problems at 23.000 miles ford put a new engine in at that time it was back in 2005 it now has 30.000 miles with no apparent problems he had it seviced at the local ford dealership i want to go to mobil 1 but need to know what you guys run in yours also how can you tell if the heads were upgraded the cobra has a cold air intake and magnaflow cat back mufflers what mods if any do you guys like to make around 50 more horsepower anything else i need to know or look out for your suggestions will be very helpful this is my 8th mustang and by far my favorite thanks rfbowers
Old Feb 9, 2007 | 11:21 PM
Blownsvt's Avatar
Blownsvt
Default RE: 03 cobra
As far as oil is concerened i think most guys will tell you they run mobil 1 fully synthetic 5w-20 in the cobras althoguh i know some guys use royal purple products. to gain aroung 50 hp your best bet is a pulley swap and tune. I would bet the heads are stock, i have't heard of anyone relly touching the heads on these cars.
Old Feb 9, 2007 | 11:25 PM
JamesTronix's Avatar
JamesTronix
Get a 2.8 upper pulley, Heat Exchanger and a dyno tune and you will easily pick up 40-70rwhp.
Old Feb 9, 2007 | 11:41 PM
rfbowers's Avatar
rfbowers
thanks for your imput what i meant on the heads was i know there was a recall on the early 02 cobras because of heat related problems on the number 7&8 plugsand thought mayby ford had upgraded the heads on the replaced engine thanks rfbowers
Old Feb 10, 2007 | 04:45 AM
italia18's Avatar
italia18
Punctuation man, punctuation. Took me a minute to read what you had to say cause theres nothing seperating it all. Anyway he pretty much answered your question.
Otherwise:
The 50 horse -- headers and a tune up.
The heads -- wont really know til you take off the valve covers.
Old Feb 10, 2007 | 02:29 PM
bigugly78cj5's Avatar
bigugly78cj5
well the tsb for the heads was released in early/mid 05, so depending on the date the motor was put in, i doubt they would used faulty heads that might potentially cost them more money down the road(assuming they put in a whole unit not just a bottom end which i cant recall ever seein at my dealership).....so i wouldnt think your car would ever have the head tick issue....... far as motor oil, i run Mobil-1 in my 03 cobra.
anthony
Old Feb 10, 2007 | 07:31 PM
rfbowers's Avatar
rfbowers
thanks guys for your imput, and yes it was long block that ford put in.
Old Feb 11, 2007 | 12:41 AM
mattmoto441's Avatar
mattmoto441
get a dynotuned pak from http://www.rpmoutlet.com/03cobra.htmi would say option A with the SCT Xcal2 Tuner 65+ is a easy mod with that then the IRS Brace is a must must must if you dont you WILL Break yours sooner or later and you wont be happy http://www.billetflow.com/irs_brace.htm
Old Feb 11, 2007 | 12:54 AM
mattmoto441
also if you have a new Long block put in they allredy have the revised heads for the tick and the cooling problem
All the SVT motors are reman motors, the motor and all the parts in the motor are brand new BUT it is not put together by ford its done by some company in Texas contracted out by ford that's why they call it a reman
you can call SVT and ask them for your self if you want 1 800-367-3788
Dose you motor have the build tag on it still andare your valve covers still painted?
itshould not have a tag on the motor sense it wasnt assembled by ford they only do that when they come from the romeo plant,
Old Feb 12, 2007 | 05:07 PM
CobraBob's Avatar
CobraBob
Initially Ford stated that only Cobras built before 11/02 were prone to develop the tick issue due to the inferior cooling passages of the current head. That was laterchanged when it was found that even 2004s were developing the issue. So they revised the head properly and it was released in January of 2005. The part numbers are:
Left side head
Part # 2C5Z-6049-BAB
Right side head
Part # 2C5Z-6049-CAB
Any motor replaced by Ford prior to 01/05 likely has a previous release head. Unless And if so, there would be the potential for the tick issue to develop. You should be able to see the part number from beneath the car.
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sparks_88
Sep 8, 2015 01:06 PM
