SVT Forums
fuel
Old Feb 12, 2007 | 03:42 AM
DSTANG03's Avatar
DSTANG03
Default fuel
hey i have a 2v and i need to know what fuel system to run im going to be runnin around 20lbs of boost and i need to know if i have to run return or not...what do you big guys run??? thanks
Old Feb 12, 2007 | 11:35 AM
ponysnake99's Avatar
ponysnake99
Default RE: fuel
you can make 20 psi happen on a returnless system, but for simplicities sake you could convert over to a return style but you'd have to make a ton of custom changes from tappin' the gas tank for the return to new fuel rails. It all depends on your set up, i'm assuming a street set up, so you might be running 72 lb injectors, you'll have to get it tuned so check with local shops about what they would recommend
Old Feb 12, 2007 | 04:58 PM
spray175's Avatar
spray175
Default RE: fuel
Just curious what are your mods? Built motor?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
