EvenFlowCooling
Has anyone on this board installed the EvenFlowCooling setup? Apparently it is a very basic setup that puts a T-fitting on the radiator hose and runs the coolant directly to the drivers side head.
Do you think it will work, or is it just another hose?
Yep it will work. There is that and then the LDC cooling mod. The even flow cooling mod is cheaper and will get the job done but you can see it in the engine bay. The LDC cooling mod is installed behind the supercharger but taking the transmission out. The even flow you should take the supercharger off.
Ez Does it
Mar 25, 2011 10:25 PM
