SVT Forums
2003 COBRA BATTERY PROB?
Old Mar 15, 2007 | 10:00 PM
ZO6AINTPOOP's Avatar
ZO6AINTPOOP
Default 2003 COBRA BATTERY PROB?
WHEN MY 03 COBRA UNDER BOOST BATTERY LIGHT FLICKERS ON AND OFF? ITS BOOSTIN 15PSI
Old Mar 15, 2007 | 11:37 PM
wes ley n the G T's Avatar
wes ley n the G T
Default RE: 2003 COBRA BATTERY PROB?
Check your alternator. Could be when you enter a good amount of boost the alternator isn't doing its job. Could be a pulley making it do that, I'm not sure of your setup tho.
Old Mar 15, 2007 | 11:58 PM
ZO6AINTPOOP
It has a Brand new Alt. and I wonder If It is belt slip causing it to come on only a thought but I have a 100mm upr Idler but i'm running a stock belt should I go with a smaller belt??
Old Mar 16, 2007 | 01:16 AM
wes ley n the G T
Yea check the belt, slippage could be the problem. It seems like when you enter boost since you're running that much boost, it sounds like your belt is slipping on the alternator pulley because whenever the alternator drops below a certain amount of output, it will trigger the battery light.
Check the battery, if the battery is holding a charge at the normal level, then its most likely the alternator pulley slipping on the belt.
Old Mar 23, 2007 | 11:14 PM
BTRStang's Avatar
BTRStang
+1 on belt slipage
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
junior04
Sep 28, 2015 10:53 AM
