SVT Forums
What the!?!
Old Mar 17, 2007 | 12:36 AM
cencalmatt's Avatar
cencalmatt
Default What the!?!
OK good then, let's try this again shall we... Surely SOMEBODY can inform me of a method they have used to succesfully program a remote pad. Nobody has? I find that hard to beleive. Anyway, I do not have a manual and apparently there's dozens of ways to do it according to internet research. I don't want to waste my time trying and possibly screw something up. All I need is someone who's done it and is kind enough to inform me how. Thanks.
Old Mar 17, 2007 | 02:17 AM
Blownsvt's Avatar
Blownsvt
Default RE: What the!?!
what do you mean by remote pad? whats it for?
Old Mar 17, 2007 | 03:10 AM
Blownsvt's Avatar
Blownsvt
How to reprogram your remote entry
transmitters
You must have
all remote entry transmitters
(maximum of four) available before beginning this
procedure.
To reprogram the
remote entry
transmitters:
1. Ensure the vehicle is
electronically unlocked.
2. Put the key in the
ignition.
3. Turn the key from the 2 (LOCK) position to 3
(OFF).
4. Cycle eight times rapidly (within 10 seconds)
between the 3 (OFF) position and 4 (ON).
Note:
The eighth turn must end in the 4 (ON) position.
5. The doors will lock, then unlock, to confirm that
the programming mode has been activated.
6. Within 20 seconds press any button on the remote
entry transmitter.
Note: If more than 20 seconds
have passed you will need to start the procedure
over again.
7. The doors will lock, then unlock, to confirm that
this remote entry transmitter has been programmed.
8. Repeat Step 6 to program each additional remote
entry transmitter.
9. Turn the ignition to the 3 (OFF) position after
you have finished programming all of the remote
entry transmitters.
Note: After 20 seconds, you will
automatically exit the programming mode.
10. The doors will lock, then unlock, to confirm that
the programming mode has been exited.
Old Mar 17, 2007 | 03:41 AM
cencalmatt's Avatar
cencalmatt
Awesome thanks! This is one of the methods I read somewhere else but I'm glad you confirmed it. Either nobody else knows or everybody does and wouldn't help me. Oh well Thanks again.
Old Mar 17, 2007 | 03:28 PM
Blownsvt's Avatar
Blownsvt
no problem, at first i wasn't sure what you meant by remote pad, i thought you meant for like a garage door or something lol.
Old Mar 20, 2007 | 02:21 PM
MuscleOwnzRice's Avatar
MuscleOwnzRice
i just did that recentley too, ford wanted to charge 75 bucks, i knew there must be a way and figured it out. Should be a sticky
