anyone dyno a stock terminator?
RE: anyone dyno a stock terminator?
They vary quite a bit - a lot of Terminators with low mileage (under 10k) tend to dyno on the lower side of 370rwhp. Stock but 10k+ mile 03/04's have loosened up a good amount and many have seen 380rwhp+ stock.
ORIGINAL: Dan04COBRA
when mine was dynoed it had 12k on it
ORIGINAL: beastzilla02
no way is there a 70hp loss through the manual transmission..if they are really at 420hp then 390 rwhp
My 465hp 351W ( verfied on engine dyno and have chart to prove it )
made 370rwhp on dyno jet
You lose a good bit of power thru the drive train. 18% loss is correct.
My 03 Cobra dynoed yesterday at 390 rwhp. It has approx. 17000 miles. Bone stock--including air filter................I just brought the car to Stang-Hi in Baton Rouge, La., and I'm getting a ported Stage IV (Steigmeier) eaton put on with a 2.93 pully and a 2 lb. lower pully. I'm also getting a JLT straight shot air, new magnaflow catted x pipe, and magnaflow cat-back installed. I will get it dynoed and tuned with a SCT tuner. I'm also getting a fresh oil change with royal purple, a new clutch quadrant cable and bracket, new flundyne heat exchanger, left head cooling mod done, new lower conrol arms, boost overlay gauge, new plugs, pully tensioners, and with all this, I hope to make the 500 rwhp club, Wish me luck.......................I'll list the dyno numbers in a week or so, when he's finished.................
