SVT Forums
Cooling mods
Old Jun 6, 2007 | 04:26 PM
Zoie_daGT's Avatar
Zoie_daGT
Default Cooling mods
Hey,
I had a quick question about the cooling mods for Cobras. I just swapped an 03 Cobra shorblock into my car. I remember hearing that there is a way that you can reroute coolant so that cylinders 4 and 8 cool better but idk. Is this cooling mod done to the block or the heads. ANy info would be appreciated. THanks
Old Jun 7, 2007 | 11:07 PM
Zoie_daGT's Avatar
Zoie_daGT
Default RE: Cooling mods
bump
Anyone have an idea???
[align=left] [/align]
Old Jun 8, 2007 | 01:27 AM
Blownsvt's Avatar
Blownsvt
theres a couple of kits out there, look at lighting force performance or lethal performance, most require you to remove either the blower or the transmission for installation.
Old Jun 8, 2007 | 02:58 AM
Zoie_daGT's Avatar
Zoie_daGT
Thanks. I checked out LFP. I saw a HEAD cooling kit. I just have the shortblock. I was thinking that the cooling mod was to the block itself. THanks for the tip.
Old Jun 8, 2007 | 12:41 PM
Blownsvt's Avatar
Blownsvt
nope as far as i know it it just for the head
Old Jun 8, 2007 | 12:50 PM
ZAXJAX's Avatar
ZAXJAX
The only cooling mods are heat exchanger, intercooler expansion tank, and the head cooling mod.
Old Jun 8, 2007 | 02:38 PM
PSR's Avatar
PSR
The coolant modification has never been proven to do anything what so ever it is just someone’s thought. I personally have never had it on my car and never had a heat problem either
Old Jun 9, 2007 | 02:46 AM
xxkazp3rxx's Avatar
xxkazp3rxx
The head cooling mod was thought of as a good idea, because the pistons were popping before the fix was given to the Cobra owners. The #7 and 8 heads do not havea way to have coolant to escape like the other heads, creating basically a sauna in those heads, and to much pressure can cause them to expand. When all those Cobras were going down from the #7/8 heads, that was the explantion Ford gave. The #7/8 heads failed due to excessive heat due to running boost for to long.
The Even Flow head cooling mod goes on the top of the motor, and the LDC Chicago goes underneath, but you have to drop the tranny to do it.
The basic cooling modifications to do to the cobras are: Heat exchanger, T-stat, Head cooling mod, and radiator. The expansion tank does relativly nothing. Just holds more in the resevoir.
BOB ROME
Jul 26, 2023 01:54 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
