SVT Forums
Lethal Performance /Fore Precision Fuel Hats Available Now!!
Old Jul 20, 2007 | 08:37 PM
Boostaddict's Avatar
Boostaddict
Former Sponsor
Default Lethal Performance /Fore Precision Fuel Hats Available Now!!
Lethal Performance/Fore Precision 03-04 Cobra Billet Top Hat
http://www.lethalperformance.com/pag...t-top-hat.html
**Available EXCLUSIVELY through Lethal Performance**
If you haven't seen one of Fore Precision Works products you can't even imagine the level of quality they have. So we're here to give you the newest and baddest piece ever released onto the mustang market by Fore Precision Works
This all new billet top hat made by Fore Precision Works is the cutting edge of fuel system upgrades for the 03-04 Cobra's. CNC machined from top notch billet aluminum then anodized for a long lasting protective finish. Offered in 2 different styles you can be sure that this hat will meet your need for a higher quality and more efficient top hat modification
Choose between:
Single 8an Outlet (Built in Y Block) which includes an extra port for a return line
or
Dual 6an Outlets
-Accommodates Dual Ford GT fuel pumps as well as wiring for Single or Dual FPDM's (Fuel Pump Driver Module)
-Direct replacement and bolts right in using an OEM gasket for a perfect seal as well as using the OEM fuel sending unit in the same stock location.
-Eliminates the PPRV and offers a direct in-tank hose routing to both fuel pumps for optimum fuel delivery.
-Two pairs of gas blocked 12 gauge conductors using 12ga Mil Spec fuel resistant wires for fuel pump wiring to the FPDM(s). This allows your Ford GT pumps to operate without losses from undersized OEM wires and will help in dropping duty cycle. Wiring for the ground and fuel level sender also included.
-No welding or caulk used in assembly or manufacturing. Full billet components use o-rings, OEM seals, and gas blocked through conductors.
-All assemblies are pressure tested prior to shipping.
The top hat includes:
[*]CNC Machined & Anodized Top Hat Assembly[*]All Gas Blocked wiring for the Pumps, Ground and Level Sender including the proper spade connectors to connect the wires to each fuel pump[*]Pre-cut and installed Gates 30R10 Submersible Fuel Hose for each pump[*]All XRP an Fittings[*]New Bolts for mounting the assembly to the fuel tank
Note: The Top hat assembly when purchased alone does not include: Fuel Pumps, Filters, Socks as well as the Fuel Level Sender or OEM Gasket. These are items which can be reused from your stock hat assembly or purchased seperately.
The Lethal Peformance/Fore Precision Works top hat can be purchased by itself or as a fully assembled fuel system along with pumps, lines, rails, Modifed FPDM or Dual FPDM with wiring harness.
[IMG]local://upfiles/32299/A7C52F4A3CFA4470B6EAF76178F6BD78.jpg[/IMG]
[IMG]local://upfiles/32299/E5BCD6BC92334316A654F3C464D392E5.jpg[/IMG]
[IMG]local://upfiles/32299/348CCB171F634B1080A449E2B021BA17.jpg[/IMG]
carid
Jul 8, 2016 09:55 AM
Wombatnation
Sep 13, 2015 09:16 PM
tramphardrocker
Sep 13, 2015 08:56 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
