SVT Forums
The T45 Tranny.
Old Aug 6, 2007 | 01:53 AM
Black Snake's Avatar
Black Snake
Default The T45 Tranny.
Just purchased the Cobra and I relized that it whines a bit in 3rd and 5th gears. This Normal for these trannys? I mean Of course its not normal but do they traditionally whine when they are worn? I know the T-5s did it.
Old Aug 6, 2007 | 11:09 AM
Ahnial8u's Avatar
Ahnial8u
Default RE: The T45 Tranny.
Mine had some :Whining" while the clutch was pressed in in all gears and now I have no 3rd 4th and needs new synchros for 5th. T-45 = JUNK!!!
I'm replacing it with A T-56 hopefully. I would take it easy untill your ready to replace it.
Old Aug 6, 2007 | 08:56 PM
Black Snake
T-56 Direct bolt on?
Say the t-45 goes out can I use the T-5 as a replacment for now until I get money for an upgrade?
Old Aug 6, 2007 | 11:41 PM
Ahnial8u's Avatar
Ahnial8u
Another thread I started over there.
http://www.corral.net/forums/showthread.php?t=938964
Dont Quote me but the T-5 will not work!
You need a 3650 or a 3550 with a Modular Bellhousing.
Old Aug 6, 2007 | 11:46 PM
2000GT4.6's Avatar
2000GT4.6
Whatever you do, don't replace it with a 45. I did this twice before I got smart and ordered a TKO 500.
here is a link about 56/500/600 swaps:
https://mustangforums.com/m_2832353/tm.htm
The 45 is junk. However, just because its making noise doens't mean its on its way out. Both times I ruined mine it was grinding 3rd/2nd before it died. If its not grinding, your probably OK for now.
One thing, DONT powershift/speedshift a 45. This just really seems to tear them up, both times I ruined my 45 I was shifting hard/fast and got a big grind,
Old Aug 7, 2007 | 02:09 AM
Black Snake
Yea its not a grinding noise but more of a whine. It seems to get quieter after it heats up.
Old Aug 7, 2007 | 11:35 AM
Ahnial8u's Avatar
Ahnial8u
This is exactly how mine went out. Went to shift into 3rd it ground a little and I tried to slam it and that was all she wrote.
Old Aug 9, 2007 | 08:34 AM
CobraBob's Avatar
CobraBob
If you have normal gear noise, adding a set of my shifter gaskets (I have them for the T-56, T-5, T-45, etc.) will quiet it down. It's a very inexpensive and effective mod. http://stangshiftergaskets.com/index.htm
prophotog
Sep 15, 2015 08:38 AM
NeoTokyo
Mar 10, 2004 07:05 PM
Mystic Cobra 96
Feb 23, 2004 10:51 PM
Mystic Cobra 96
Feb 17, 2004 09:44 PM
Mystic Cobra 96
Jan 11, 2004 07:55 PM
