SVT Forums
4v swap
Old Aug 6, 2007 | 06:23 PM
mrounds06's Avatar
mrounds06
Default 4v swap
im getting an 03 cobra motor to put into my 2000 gt. im only gettin the motor, and ecu. what else do i need to complete this conversion and how much am i looking to spend. tranny comes with the motor too
Old Aug 6, 2007 | 06:44 PM
xxkazp3rxx's Avatar
xxkazp3rxx
Default RE: 4v swap
You need to overhaul your suspension... you have the ecu, tranny and motor... you really need the suspension also...
Old Aug 6, 2007 | 11:33 PM
bugpack28's Avatar
bugpack28
Default RE: 4v swap
yahh man its a lot of work and mabe think of just building your engine and gettin a stroker 5.1L kit with a supercharger? Might be cheaper that way same hp or so and a lottttt less work...
Old Aug 7, 2007 | 04:26 PM
ZAXJAX's Avatar
ZAXJAX
Default RE: 4v swap
The suspension on the GT is great for track applications. A lot of guy over at SVT Performance are running a solid axle for racing. The IRS is a real pain to bulletproof but can be done. Keep your rear!
Old Aug 7, 2007 | 04:58 PM
xxkazp3rxx's Avatar
xxkazp3rxx
Default RE: 4v swap
I wasn't talking about going to the Cobra suspension... I meant he has to really fortify everything... his stock axle wont do much but break if he doesn't fortify it...
Old Aug 8, 2007 | 01:27 PM
jman511115's Avatar
jman511115
Default RE: 4v swap
ORIGINAL: xxkazp3rxx
I assumed you were talking about the front suspension. Aren't the 4 valve motors quite a bit heavier? I'm thinking about doing this swap too, but precious little information is to be found on the topic.
BTW, priced out a rear end build with an electronic locker and excluding new gears, came out to a little under $1200.
Old Aug 8, 2007 | 01:43 PM
xxkazp3rxx's Avatar
xxkazp3rxx
Default RE: 4v swap
the 4v motor is heavier... you have the extra stuff inside + 55lbs for the blower + blower accessories....
I would just build it up as much as you could....
Old Aug 8, 2007 | 04:26 PM
jman511115's Avatar
jman511115
Default RE: 4v swap
Aren't the heads larger and heavier too?
Edit: I've heard somthing about needing a guage cluster from a Cobra, why is that?
Old Aug 8, 2007 | 04:32 PM
xxkazp3rxx's Avatar
xxkazp3rxx
Default RE: 4v swap
for the right speedo, and all that... unless you just want to reflash your stock GT one... i guess.
Old Aug 9, 2007 | 12:02 AM
jman511115's Avatar
jman511115
Default RE: 4v swap
Any K member or other chassis parts need to be modded?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
