Stock 03' Cobra....Want to make it 600HP????
RE: Stock 03' Cobra....Want to make it 600HP????
its not all about power alone, my best adivce would a wet shot (take your pick at size) and then swap a straight axle... then youll be cooking, stock for daily driving - and fast as hell on spray when you REALLY need it.
pish-posh, stopping is over-rated.
after reading up on the HP TT kit, Id jump on it if I had a drag only car, but not would I would want fora DD, IMHO. www.kennebell.net
ORIGINAL: Ellik
Kenne bell is def a good start but having a rare Cobra with a TT kit is something def worth having. Sure it gives you A LOT of power but umm well I wouldnt say that would be enough for me
Its not like all you need to buy is the HP TT kit. You need fuel system as well. Which for that amount of horsepower it will get pricey. You will most likely spend 12k on a turbo build. Also the Hp kit comes with front suspension. Plus clutch upgrade, input shaft, IRS mods or Rear axle and much more.
Here is everything you need to know about the 03/04 Cobra's.... happy reading, this is where I started when I started learning about the terminators.
http://stangshiftergaskets.com/2003_2004faqs.htm
