SVT Forums
How much power should i make?
Old Oct 2, 2007 | 08:28 PM
BADSEED's Avatar
BADSEED
Default How much power should i make?
im thinking of doing a 03-04 cobra motor/trans swap in my 99 GT how much power and what times should i be running with a pullie. tune, CAI, exhuast and a 50 shot?
Old Oct 2, 2007 | 08:47 PM
mfj's Avatar
mfj
Banned
Default RE: How much power should i make?
i would say around 500 - 550 rwhp. A lot of unknowns though.
Old Oct 2, 2007 | 09:07 PM
BADSEED's Avatar
BADSEED
ORIGINAL: mfj
if i got a bigger intercooler and used like a 100 shot you guys think i could hit 600rwhp and then i probably need to upgrade my fuel system
Old Oct 2, 2007 | 10:12 PM
StylinM6s's Avatar
StylinM6s
Damn what a major modification here. Well for one thing your GT would be a huge sleeper. After you do all that you will need to change at least 3 other things as well. They're just a must and I'm sure there is more.[/align][/align]Wider tires, need better grip with more power[/align]Brakes[/align]Suspension upgrade[/align][/align]
Old Oct 2, 2007 | 11:37 PM
ZW99GT's Avatar
ZW99GT
ORIGINAL: BADSEED
ORIGINAL: mfj
That was be a really nice setup in your GT.
600rwhp? You will need to upgrade your fuel system WAY before then. Good luck getting to 500 without going with a cobra pump/tank.
Old Oct 3, 2007 | 03:03 PM
BADSEED's Avatar
BADSEED
ORIGINAL: ZW99GT
ORIGINAL: BADSEED
ORIGINAL: mfj
ooo i know the fuel pump from my GT wouldnt work, but i most likly would have to change the injectors on the cobra motor, and i have pretty wide tires now 275 but probably would just run M/T's street ET's all the time....
if i do the swap i know i need to upgrade the fuel system and traction but would i need anything else?
Old Oct 3, 2007 | 03:53 PM
Crazyfast50stang's Avatar
Crazyfast50stang
Even with the 50 shot you will not be making 600rwhp. With a tune exhaust and pullie you will be around 450rwhp. With the 50 shot you will be about 510rwhp.
Old Oct 3, 2007 | 04:14 PM
xx9gt6xx's Avatar
xx9gt6xx
Agreed. That's a **** ton of work for that set up, hopfully you have a lot of time and money to be doing the swap... Good luck it would be a sleeper for sure!
jpplaw
Mar 19, 2025 08:53 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
motown girl
Aug 28, 2015 08:21 AM
