my cobra is done for a while
yea. I was looking thru the list of parts and its not forged, but it is stroked and has all new internals. I could post a list but it would be pointless. I'm thinking about putting a blower on it. I'm hoping for around 600rwhp with it, but its just wishful thinking.
its an aluminum block. Here is the parts list so you guys who know more about this can tell me how much hp and boost, etc.
ENGINE (1999 Cobra) Custom Built by VT Engines www.vtengines.com
-Original 1999 Aluminum Block Bored .020 Over With a VT Engines 302ci Stroker Kit (Good For 1500hp) 9:2:1 Compression Ratio
-CP Custom 16cc Dished Pistons .020 Over
-CP Custom matched rings
-Oliver Billet I Beam Stroker Rods With ARP 2000 Bolts
-Custom Billet VT Stroker Crank 3.75 Stroke
-VT Billet HO Oil Pump gears
-Tri Metal Bearings
-Arp Head Studs
-1999 Cobra Heads(port & polished, resurfaced, pressure tested, 3 angle seat cut, and valves cut and cleaned)
-Crower 4v 31mm Stainless Valves
-Crower 4v Springs and retainers
-COMP 4v Regrind Cams
-Felpro Perma Torque MLS Head Gaskets
-Metco 8lbs Lower
-Metco 3.7 Alternator Pulley
-New thermostat
-Custom Tuned by SCT racing Tuner (Tuner, Chip, Software and Laptop Included)
INTAKE
-42lbs Injectors
-Ported Throttle Body
-PortedUpper/Lower Cobra Intake
-80mm MAF
-K&N Filter
DRIVETRAIN
-TKO 5 Speed Transmission (1500 miles)
-Lakewood SFI Bellhousing
-Spec Stage4 Clutch
-Spec Aluminum Flywheel
-Custom sized and balanced Aluminum Driveshaft
-UPR Short Throw Shifter
-UPR Double Lock Extreme Firewall Adjuster
-UPR Quick Release Clutch Quadrant
-Ford Racing 4.10's
-Ford Racing Live Axle Swap
EXTERIOR
-2001 Cobra Rear Bumper (Change to have COBRA seen in the back instead of MUSTANG)
-Front Grille Snake Emblem
SUSPENSION
-UPR Tubular Front K-member and A-Arms
-Front Coil over springs
-5-way adjustable struts
-QA1 Caster/Camber Plates
-H&R Sport Springs
-Granatelli Motorsports Upper and Lower Control Arms w/poly bushings
-Drag Launch Springs
-UPR Subframe connectors (Weld-on)
ELECTRONICS
-SCT tuner 4 bank chip
-Kenne Bell Fuel Flow Booster/Controller
-Ignition Controller/Booster
-Autometer Shift Light
-Autometer Air/Fuel Meter
-Autometer Boost Guage
-IBM ThinkPad Laptop (SCT Custom Tuning Software)
EXHAUST
-Bassani Mid Length Headers
-ARP Header Studs
-Bassani Catless H-Pipe
-Flowmaster Catback
-Bassani Catback (Not Installed on car but included in the price)
FUEL SYSTEM
-2003 Cobra Twin Pumps Assembly
-Cobra Baffled Fuel Tank
-42 lbs injectors
-Tri Metal Bearings
-Arp Head Studs
-Metco 8lbs Lower
-New thermostat
INTAKE
-42lbs Injectors
-80mm MAF
-K&N Filter
DRIVETRAIN
-Spec Stage4 Clutch
-Ford Racing 4.10's
EXTERIOR
SUSPENSION
-H&R Sport Springs
ELECTRONICS
EXHAUST
-ARP Header Studs
-Flowmaster Catback
FUEL SYSTEM
-42 lbs injectors
ORIGINAL: 5.0Sleeper
-Tri Metal Bearings
-Arp Head Studs
-Metco 8lbs Lower
-New thermostat
INTAKE
-42lbs Injectors
-80mm MAF
-K&N Filter
DRIVETRAIN
-Spec Stage4 Clutch
-Ford Racing 4.10's
EXTERIOR
SUSPENSION
-H&R Sport Springs
ELECTRONICS
EXHAUST
-ARP Header Studs
-Flowmaster Catback
FUEL SYSTEM
-42 lbs injectors
-Tri Metal Bearings
-Arp Head Studs
-Metco 8lbs Lower
-New thermostat
INTAKE
-42lbs Injectors
-80mm MAF
-K&N Filter
DRIVETRAIN
-Spec Stage4 Clutch
-Ford Racing 4.10's
EXTERIOR
SUSPENSION
-H&R Sport Springs
ELECTRONICS
EXHAUST
-ARP Header Studs
-Flowmaster Catback
FUEL SYSTEM
-42 lbs injectors
ur block can handle a lot of boost.. billet rods are stronger than forged rods.
sweet. I was pretty sure it was done well. I might be looking at a centri blower cause of it being my dd. I'm gonna get it tuned and dyno'd monday so I can get some numbers too.
Did you get your estimate blown? When mine went down, I rebuilt my stocker with CP pistons, brand new heads, whipple, 60s, Accufab and all the associated parts/labor for around 10-11 grand. All parts were brand new. The engine rebuild by itself was 5k.
