SVT Forums
started swap for t56 trans?
Old Nov 3, 2007 | 06:15 PM
slick88's Avatar
slick88
Default started swap for t56 trans?
removed all the wiring removed cat back h pipe snapped 2 flange bolts for the h pipe on header now trans is stuck lol any sugestions for how to get trans un stuck i tryed to work it back an forth but it did not work also tryed prying it i think it might be stuck in the pilot bearing any info helpfull
Old Nov 3, 2007 | 10:17 PM
Ahnial8u's Avatar
Ahnial8u
Default RE: started swap for t56 trans?
Is the trans stuck on the bolts, or something inside the tranny?
Old Nov 4, 2007 | 02:28 PM
slick88's Avatar
slick88
all bolts are removed i check it twice and i al so checked to see if it was geting hung up on something else but its not i was thinking of prying it from both sides what u think. did u have this prob when u did your trans
Old Nov 4, 2007 | 05:09 PM
mfj's Avatar
mfj
Banned
when i did my transmission, just used a chisel and hammer on one side and it came loose. i think u might have missed a bolt.......
Old Nov 4, 2007 | 05:43 PM
97targa's Avatar
97targa
Don't forget to jack the front of the motor up so that the back end angle down enough to slide the tranny out! You could also run a ratchet strap under the dampener to each strut tower and start cranking! Your trans is prob hitting the firewall and this will prevent that!
Cannibal_carnies
Mar 2, 2023 06:17 PM
djbigskrilla
Sep 20, 2022 01:04 AM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
PearlGenPu
Aug 12, 2015 01:57 PM
