SVT Forums
Clutch went out
Old Nov 9, 2007 | 10:02 PM
White99Cobra's Avatar
White99Cobra
Default Clutch went out
well i was driving on the highway today and my buddy pulls up next to me in his 93 z28 and he guns it a little so i go to down shift and as soon as i get the clutch all the way in i hear a pop and feel it in the clutch and now the clutch is looser than it was before and it won't go into any gear. i think its the clutch spring but i'm not sure. i got the car about 3 weeks ago and i have a 3 month warranty on it so i shouldn't have to pay for it. if you guys think its anything else let me know thanks.
Old Nov 10, 2007 | 02:49 AM
mfj's Avatar
mfj
Banned
Default RE: Clutch went out
sounds like ur throw out bearing took a ****,
Old Nov 10, 2007 | 10:19 AM
slick88's Avatar
slick88
throw out fork might be broken mine broke i couldnt get any gears and i agree with the other guy throw out bearing is prob bad it might have mest up the forks on the pressure plate
Old Nov 10, 2007 | 06:09 PM
xx9gt6xx's Avatar
xx9gt6xx
ORIGINAL: mfj
Yup...
Old Nov 10, 2007 | 07:54 PM
xxkazp3rxx's Avatar
xxkazp3rxx
Only one problem with that...
Clutch is a wear and tear item... it's probably not covered.
Old Nov 10, 2007 | 08:41 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Are you sure the cable hasnt snapped? A clutch isnt that bad of a job, with proper tools it should only take about 3 hours.. Dont forget to resurface the flywheel
Old Nov 12, 2007 | 08:10 AM
White99Cobra
i don't think its the clutch because the clutch was brand new. i think its the transmission not the clutch now, but the car is at the dealership right now and i haven't heard from them yet. i hope its just an easy fix, but it probably isn't.
Old Nov 12, 2007 | 09:02 AM
94snake's Avatar
94snake
probably a clutch cable. should have tried to start it in first see if it was engaged. i just had to put a clutch in my car and the cable didnt snap, but stretched enough to where i couldnt put it in any gear. so i just started it in first or reverse, and shifted without a clutch.
Old Nov 12, 2007 | 09:21 AM
White99Cobra
that reassures me that its not the transmission now, cause that is what mine is doing. i did try to put it in reverse with it running and the clutch in and it was grinding. well i hope its just a cable or spring, it would be an easy fix then.
Old Nov 12, 2007 | 01:00 PM
White99Cobra
the dealership called me and they think that the clutch went bad. does the clutch make a pop when it goes out?
