SVT Forums
1996 mystic cobra
Old 11-13-2007, 10:26 PM
99whitecobra
99whitecobra's Avatar
Default 1996 mystic cobra
has ticking noise when first warming up, then goes away after the car has been ran for awhile, any ideas? does it need an engine rebuild
99whitecobra is offline
Old 11-13-2007, 11:29 PM
mfj
Banned
mfj's Avatar
Default RE: 1996 mystic cobra
in short, no... sounds fine to me...
mfj is offline
Old 11-14-2007, 12:11 AM
94snake
94snake's Avatar
well heres what i think you should do. come to my house, ill give you my keys and title, you give me your keys and title. lol no ive wanted a mystic like my entire life. beautiful cars you should feel lucky. but try adding some lucas oil stablizer to your next oil change. hopefully you change your oil with mobil 1 or some sort of synthetic. youll probably only find it at autozone or advanced auto parts, ive only seen it there. they can tell u all about it.
94snake is offline
Old 11-14-2007, 10:54 AM
99whitecobra
do you think that will fix it, because i have heard that cobra engines tick alot, is this mainly because of people using the wrong oil? or what? thanks it only has 77k on it so i wouldnt think it would need a rebuild?
greg
Old 11-14-2007, 01:55 PM
94snake
94snake's Avatar
i seriously doubt you need a rebuild. and ive not heard that cobra engines tick. mine doesnt, i dont think anyone i knows does.
94snake is offline
Old 11-14-2007, 02:51 PM
Ellik
Ellik's Avatar
the 4v top ends make a ****-load of noise. Mine does at least.
Ellik is offline
Old 11-14-2007, 05:21 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Could be the chain adjusters...Im pretty sure they are like the 2V motors and had oil actuated adjusters, once it getsrunning the oil flows to them and quits the noise. I used to think my Cobra made a lot of ticking until finally one day it just started knocking..End of that motor
WhiteFoxGT is offline
Old 11-14-2007, 05:57 PM
99whitecobra
how much did you spend on the motor
Old 11-15-2007, 01:14 PM
99whitecobra
would the ticking be a wrist pin? if so would that be an easy fix?
Old 11-15-2007, 01:29 PM
94snake
94snake's Avatar
a wrist pin? lol the only wrist pin i know of is what connects the piston to the rod. id hope that wouldnt be your troubles andno, not an easy fix lol.
94snake is offline
Quick Reply: 1996 mystic cobra
