SVT Forums
PROBLEMS COMMON OR UNCOMMON!?!?!?
Old Nov 19, 2007 | 10:58 PM
Blownsvt's Avatar
Blownsvt
Default RE: PROBLEMS COMMON OR UNCOMMON!?!?!?
one of the guys in her made mine for me. just post up in the chop shop or whatever it is, post up a few pics of your car for them to work with and they'll usually get you something
Old Nov 20, 2007 | 12:06 AM
slick88's Avatar
slick88
they use cheep rubber when they put thows bushings in i took mine out and put polyuthene bushings in there mush better than those stock ****y pieces of rubber they used i would up grade those soon.
Old Dec 9, 2007 | 07:45 AM
torqjnky's Avatar
torqjnky
The “clunk†is a moderate volume sound which typically occurs after depressing the accelerator following a coast. It is very noticeable in 6th gear in most cases. This is caused by play in the driveline (fairly normal in Mustangs). Here is the official Ford directive about this issue.
Special Service Message 17510 (1999-2004 Mustang 4.6l - Driveline Clunk During Gear Changes And/or Quick Acceleration After Coast (tip-in Clunk)
Some 1999-2004 Mustangs equipped with a 4.6 Liter engine may exhibit a 'clunk' noise from the driveline during gear changes and/or a quick acceleration just after a coast (tip-in clunk). The clunk may be present in multiple gears and is considered normal. This is caused by driveline lash reacting to the rapid response of the engine when the throttle is suddenly opened. The clunk noise has no effect on the performance or durability of Tthe vehicle. Inspect and check the driveshaft attaching bolts, axle mounts, transmission mounts and sub-frame mounting bolts for proper torque. No other service should be performed.
Effective Date: 01/26/2004
Oct 26, 2015 05:01 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
zanemoseley
Sep 6, 2015 12:58 PM
