pulley swap procedure
Looking to upgrade my pulley on my 04 Cobra, stock supercharger. I heard of two different ways, one you need to pull the snout offthe superchangerthen replace the pulleyand the other is you don't need to pull the snout off to replace the pulley, just use a puller. I have heard that if you don't pull the snout off you run the risk of damaging the shaft or bearing. Does anyone have the correct procedure on doing that?
you just need the right puller to pull it ogg straght and even. even if you take the snout off the blower which is a pita you sitt would not be able to get the pulley off the shaft. get a Billet flow pulley removal tool nd yu awill be good to go. takes labout an hour or so.
I would be happy to make you a puller if you're interested! Along with pulleys, I've made pullers for Grand Prix GTP's and Cobalt SS's for over 3 years. Granted the puller style for the Cobra will be a little different, but I'd be happy to make one for you if you're interested.
Thanks,
Nate
www.smoothflowpulleys.com
sales@smoothflowpulleys.com
Thanks,
Nate
Matt's 95 Stang
Oct 5, 2015 07:16 AM
