SVT Forums
uuuugghghhh...throttle problems.
Old Nov 23, 2007 | 01:14 AM
darcnytemare's Avatar
darcnytemare
Default uuuugghghhh...throttle problems.
alright...my throttle is sticking. when i used to run the AC in the summer it used to stick at whatever RPMS i was at when i put it into neutral. now itll idle wierd when i use the front defroster. once in a while it'll stick and i kinda have to give it a quick rev to unfreeze it. then it magically goes away.
Could this be a sensor keeping the throttle opened? I also noticed when its sticking if i turn the car off then restart it it will be fine with no issues. what could this be?
Old Nov 23, 2007 | 04:25 PM
SVTeeshirt's Avatar
SVTeeshirt
Default RE: uuuugghghhh...throttle problems.
Did you check the throttle itself? closely? this happened to me for about a day,i had a TINY piece of rubber wedged into the throttle,i must have looked past it 20 times, it looked like rubber off of a wire. Idk. Sure enough i removed it and it stuck no more.
Old Nov 25, 2007 | 12:14 AM
darcnytemare
hmmm....ill have to check that tomorrow at work. i removed the intake once before when i first got the car to seeand i couldnt find anything. ill have to double check though.
CS2007
Jun 25, 2019 09:45 PM
ChampInSD
Oct 2, 2015 04:55 AM
zanemoseley
Sep 6, 2015 12:58 PM
movielover40
Aug 27, 2015 03:26 PM
DrunknRuckus
Aug 23, 2015 10:05 AM
