i recently put 10.5's on the rear, with bf goodrich drag radials. Car hooks amzing, best purchase so far only problem is when i hit bumps a certain way it sounds like its rubbing. Anyone else have this problem?? do i need a spacer?? thanks
I just put 10.5's with Nitto 305/35-18's. When I installed them with the car on the jackstands, the tires were about 1/16" away from the IRS bolt with a 1/4" wheel spacer. Once on the ground, no problems. Low profilie IRS bolts should work also.
