SVT Forums
help me!
Old Dec 11, 2007 | 03:21 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default help me!
ok im looking at diffrent mustang engines and their strength, i know all the old pushrod stuff, but now i need your help with this
what block is made of, safe power zone, forged or not, is it easy to get power out of.
03-04 cobra
99-01 cobra
96-98 cobra
03-04 mach 1
01 bullitt
and the 96-04 gt
Old Dec 11, 2007 | 06:01 PM
EBBS_96_Cobra's Avatar
EBBS_96_Cobra
Default RE: help me!
Well, I'm no expert, but I would say the 03-04 Cobra motor will be your engine. Unless you want to build up the other motors. 03-04 motors were all forged internals, so that saves some work. Then all you need to do is put a different blower on there to make more power.
Old Dec 11, 2007 | 07:24 PM
97targa's Avatar
97targa
96-01 gt engines had cast blocks with 6 bolt crank 450hp capable
01-04gt's had cast blocks with improved designs and 8 bolt crank 450hp
96-98 Cobra's had Teskid Aluminum blocks with forged 8 bolt crank with poorly designed B heads with all forged goodies the block can handle 900+hp with some mods to the block for improved oil flow
99-01aluminum blocks, some teskid, but most aren't. Not as strong of a block as teskid 600+hp
03-04 machs are same as 99-01 I thought, but same head design as 03-04 cobra? I could be wrong!
03-04 cobra's had cast blocks with all forged internals and with added support and work to the block it can handle 1200+hp
The teskid block is ideal for lightweight and heat dissapation if you aren't going crazy HP.
Since your a veteran on Pushrod motors, let me just tell you that a modular motor costs twice the money to build as the older pushrod ones for the same hp!
Old Dec 11, 2007 | 09:28 PM
USMCrebel's Avatar
USMCrebel
thats thats what i was looking for!!!
Old Dec 11, 2007 | 11:07 PM
USMCrebel's Avatar
USMCrebel
i didnt read your vet pushrod statement, yeah, the next whatever i get will be only supercharged/ turbo'd to 450-550rwhp, then my track car is going to be a big block 557 stroker in an SN95. (i had to get my wife permission for this one.) Push rod FTW anyday.
Old Dec 19, 2007 | 08:36 AM
USMCrebel's Avatar
USMCrebel
ok so the stock blocks are pretty good, but how about the internals? exclude the 03-04 cobra i already know they're godly.
Old Dec 19, 2007 | 07:17 PM
wes ley n the G T's Avatar
wes ley n the G T
The 03 Cobra, which you already know can hold give or take 600rwhp. All others(2Valve GT's, all other 4V's) can hold about 450rwhp. A safer zone is 400rwhp without pushing the envelope to the 450rwhp mark.
Old Dec 20, 2007 | 08:17 AM
bugpack28's Avatar
bugpack28
aey aey, give or take 600hp might be a lot low like a lottttt. They have Held almost 1200hp at the wheels and 40plus lbs of boost with a stock supercharger and a hellion tt setup. It was in the jan mustangs and fast fords mag. Sickkkk setup
Old Dec 20, 2007 | 11:24 AM
USMCrebel's Avatar
USMCrebel
yeah, have a post on here about that, neat stuff.
Old Dec 20, 2007 | 08:39 PM
wes ley n the G T
ORIGINAL: bugpack28
Doesn't mean its gonna last dude. Im saying, give or take 600rwhp and the motor will last.
I saw the article in MM&FF but thats just a dyno run. Run that thing on the street for a month or two and get back with me lol. Again, I meant 600rwhp as a safe, daily drivable motor. Way more is possible, but not practical or reliable.
