SVT Forums
i need some help
Old Jan 7, 2008 | 09:21 AM
mybabyhasfourwheels's Avatar
mybabyhasfourwheels
Default i need some help
i am looking at really adding some serious HP to my 04 cobra. i cant make up my mind between either putting a KB on it or the HP twin turbo kit. Any suggestions??? Has anyone out there done any of these mods??? Also i want it to still be a daily driver. Thanks for the help.
Old Jan 7, 2008 | 09:45 AM
burn64's Avatar
burn64
Default RE: i need some help
I would do the KB or whipple. It is cheaper and you don't have to wait for the turbo's to spool up. I have the KB 2.2 at 17psi for close to 600whp and love it. It is not my daily driver, but it could be.
Old Jan 7, 2008 | 09:56 AM
mybabyhasfourwheels
how much did your KB cost with installation??
Old Jan 8, 2008 | 02:31 PM
burn64's Avatar
burn64
This should help! It was a nice spreadsheet, but did not post correctly. I can email it to you if you give me your email.
Chris's Cobra Upgrades
Part Description
Price
Exterior Upgrades
Stainless Bumper Letters
$72.05
Total
$72.05
Interior Upgrades
Denis reinhart guage install
$100.00
RacerWalsh Autometer Boost and Fuel Pressure
$391.00
Racer Walsh Autometer 2 pillar guage pod
$59.95
Raptor Chrome and green Shift Light
$97.00
Window Tinting
$160.00
MGW Radio **** Polished
$10.00
MGW Door Lock *****
$15.00
MGW cigarette Lighter
$20.00
MGW Polished A/C control *****
$48.00
MGW Polished headlight ****
$20.00
MGW Deluxe Gripper shift **** (SVT/Grey)
$50.00
Dynamic Racing Shifter Bezel
$49.30
Autometer Steering Column Bezel
$31.95
Wideband commander
$465.00
Total
$1,517.20
Drive Train Upgrades
MGWLTD Shifter
$208.60
Cobra T56 input shaft
$264.37
Clutch Install
$500.00
Steel Flywheel
$219.00
Center Force DFX clutch
$350.00
Drive Shaft Loop
$35.00
FIORE Micro-Click Adjuster and Quadrant
$84.90
Billet Flow IRS Girdle
$145.00
Total
$1,806.87
Suspension and Wheel Upgrades
Nitto drag radials 305/35/18
$600.00
CTR Ford GT Wheels 18x9 18x10
$1,050.00
Nitto Extreme Radials 275/35/18
$400.00
Total
$2,050.00
Exhaust Upgrades
Magnaflow Catback
$430.00
Dr. Gas Xpipe and install
$457.00
Total
$887.00
Performance Upgrades
Steeda Cold Air kit
$315.33
JLT Performance PCV Prefilter
$60.00
Kenne Bell / Boost a pump
$3,799.00
Gords Heat exchanger with fans and Logo
$822.45
55lb injectors
$500.00
Modular Powerhouse Install and dynotune + Plugs
$874.00
Thuder Racing Metco Idlers (2-90mm and 1-100mm)
$205.88
Horse Power By Herman KB oilspray kit
$393.10
Racer Walsh 55lb Injector adaptors
$139.10
Accufab Polished Big Oval Throttle Body
$359.00
SouthFlorida Pully HQ Gatorback belt 4080740
$40.00
Mjchip Maf extender
$90.00
SCT chip tune
$325.00
Stock 90mm Maf
$211.25
BBK Chrome Inlet Pipe
$282.48
Kenne Bell 3.0 inch non slip pulley
$180.00
K&N engine breathers
$49.95
Brisk GOR15LGS spark plugs
$79.99
Kenne Bell Boost a spark
$200.00
Total
$8,926.53
[font=arial][size=5][b]Tot
Old Jan 8, 2008 | 05:55 PM
Blownsvt's Avatar
Blownsvt
the kb will be alot cheaper in the long run, but the turbos will yeild more power and more effieciency. i am doing a hellion turbo swap right now. i had some machining work done and am doing a way extreme fuel system but total not including the solid axle for the rear is hovering at right around $20,000.
the hellion t-76 turbo kit alone is about 7k. and you still need all the miscilaneous stuff, inake mani, fuel upgrades, throttle cables, alternator and brackets the list goes on.
Old Jan 8, 2008 | 10:59 PM
SVTeeshirt's Avatar
SVTeeshirt
KB is def more practical... Turbos are fun though..
