Help with stock supercharger
Hey guys, been awhile since I've been on, but it's winter, and that means it's mod time. My brother is buying me a Stiegemeier port job, and I'm ready to pull the supercharger off the intake manifold. For some reason, it doesn't come right off like I thought it did, and I don't see my handy Chiltons around anywhere. Any help would be appreciated, TIA.
-Tyrell
-Tyrell
does it lift up a bit? if so you have ti lift the snout and have someone hold it ir prop it up so that you can remover the 4 bolts on the front where the intercoller pump is attached. once that is remover the blower should come free form the lower intake manifold. then you will have to remove the cac from the bottom of the blower. be very carefull in doing that as the bolts that hold that on are very soft and prone to breakage, if you need any other help let me know. i have dine this a few times. i might even be ablt to find our old write upon it somewhere,
Galactic
Apr 29, 2019 02:56 PM
ernesto-619
Sep 10, 2015 01:32 AM
Sep 3, 2015 07:14 PM
