SVT Forums
Help!!!! Fuel pump?
Old Jan 27, 2008 | 08:01 PM
mdoan's Avatar
mdoan
Default Help!!!! Fuel pump?
Alright, so here's the deal. Spent the day puttin' on a new set of shocks, and get in to test 'em out. The car starts for about half a second, and dies out. From then, it won't start. The starter's working just fine as far as I can tell, and the engine's turning over. The voltage on the battery is also fine. Just to make sure, I hooked it up to a friend's car w/ cables and got the same response. I also checked all the fuses, most importantly the fuel pump fuse. The car has about 92k miles on it, and I know the fuel filter is pretty old; anyone have any other ideas before I spend the money on a new pump? Thanks!
Old Jan 27, 2008 | 08:12 PM
bigmoose15's Avatar
bigmoose15
Default RE: Help!!!! Fuel pump?
borrow a fuel pressure guage from your local auto parts store and check the pressure before you buy a pump. also listen for the pump to turn on when you turn on the ignition.
Old Jan 27, 2008 | 08:22 PM
mdoan's Avatar
mdoan
Yeah the pump sounds like it's turning on;will do, thanks
Old Jan 27, 2008 | 09:47 PM
SVTeeshirt's Avatar
SVTeeshirt
Is it cranking at all or no? if not its probably something electrical...
Old Jan 28, 2008 | 10:09 AM
mdoan's Avatar
mdoan
No it won't crank at all, just turn over. New theory, though. Apparently the fuel shut-off switch is in the trunk, and I had to remove all the interior fiberglass carpeting to get to the rear shocks; 2+2 = 4 = I bet I idiot-bumped the shut-off switch; I'll post when I get a chance to check it out. Thanks for the help
Old Jan 28, 2008 | 02:54 PM
redeye's Avatar
redeye
I ♥ Acer
ORIGINAL: mdoan
let us know . i caught you on the other forum
Old Jan 28, 2008 | 05:55 PM
mdoan's Avatar
mdoan
haha nice. Alright the problem has been solved. The inertia switch wasn't reset, butthe enginefired briefly when the switch was disconnected, rather than not at all. So I pulled off the switch and as it turns out, one of the three connection nodes on the bottom was solid black. A little steel wool and bam, she fired right up. Imagine that. It was definately a lucky find. Thanks for the help!
Old Jan 29, 2008 | 10:34 AM
redeye's Avatar
redeye
I ♥ Acer
ORIGINAL: mdoan
no problem man glad i could help out
Old Jan 30, 2008 | 02:38 AM
JayDs Ibanez's Avatar
JayDs Ibanez
does a 97 gt have a fuel shut off switch? i never knew the stangs had one
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
