SVT Forums
TB question
Old Jan 28, 2008 | 04:00 PM
Ecstasy's Avatar
Ecstasy
Default TB question
well we all know 96-98 cobras come stock with twin 57mm, so im going to upgrade, the thing im curious about is wiether or not to go with a twin 62mm or twin 65mm, i figure twin 65mm = too big and would end up hurting me, but with full exhaust, jlt cai, a twin 62mm with a bigger maf would help me a bit.
Old Jan 28, 2008 | 05:36 PM
darcnytemare's Avatar
darcnytemare
Default RE: TB question
bump....im curious. I was thinkin bout getting a twin 65mm TB. if its going to hurt my power I might as well get the twin 62mm instead.
Old Jan 28, 2008 | 09:53 PM
Ecstasy's Avatar
Ecstasy
well im 99% positive it would because it flows almost 1700cfm if not more, and thats a bit much for anything non forced induction unless you do a serious h/c swap with nice intake porting & maybe removing the imrc plates.
Old Jan 29, 2008 | 08:16 AM
OzzDOA's Avatar
OzzDOA
The stock throttle bodies flow well enough that they really aren't a restriction point until you start making around 600 HP on the 4v's. The real restriction is with the intake manifold and heads. I've seen articles where a PnP or extrude hone on those parts will increase flow around 20%.
Old Jan 29, 2008 | 08:24 PM
xx9gt6xx's Avatar
xx9gt6xx
ORIGINAL: OzzDOA
+1...
MM&FF did dyno testing on the early 4v motors and only saw 1-3hp increase AT THE CRANK w/ an aftermarket throttle body... Not worth the $300+ they're going for...
Old Jan 29, 2008 | 10:42 PM
Ecstasy's Avatar
Ecstasy
well i plan on doing a full port job on the heads and honing the intake and removing the plates, unless i can find an aftermarket intake that will fit a 96 cobra, and maybe some 01 heads, with a 99-01 intake. but id rather keep my stock heads & find an aftermarket intake but i dont know of any. so help? lol
Old Jan 30, 2008 | 08:58 AM
baino's Avatar
baino
JLT CAI. They sell a 96-98 CAI and RAI. There is an inake thread that has this same discussion with different pros and cons of each intake.
Old Jan 30, 2008 | 11:28 PM
Ecstasy's Avatar
Ecstasy
the jlt is not an intake, its considered induction, and yes i have the jlt induction already, the fenderwell mount, i want an actual aftermarket intake manifold. and i dont know anybody that makes aftermarket intake manifolds.
Old Jan 31, 2008 | 08:25 AM
OzzDOA's Avatar
OzzDOA
There is a guy on SVTperformance.com that hones stock intakes and the word is he does awesome work. You might want to contact him.
Old Jan 31, 2008 | 08:51 AM
baino's Avatar
baino
I think sullivan makes a manifold but its still better to get stock ported and polished. The fenderwell JLT mount is called a "Cold Air Intake", which is why i thought that is the induction component you meant.
