SVT Forums
2.8 kenne bell
Old Jan 28, 2008 | 09:35 PM
zincsvtcobra85's Avatar
zincsvtcobra85
Default 2.8 kenne bell
Im planning on buying a kb 2.8 for my 03 cobra. I planning on getting 60 lbs injectors, maf, kooks long tubes with catted x pipe, already have borla stringer cat back, k and n cold air, kb boost a pump, better fuel pumps, and get it tuned by james at RWTD. What of these supporting mods would you change and how much power to the rear tires would i be looking at?
Old Jan 29, 2008 | 03:46 AM
lazyeye's Avatar
lazyeye
Default RE: 2.8 kenne bell
depends how much boost you will be running.
Old Jan 29, 2008 | 07:40 AM
Blownsvt's Avatar
Blownsvt
i think your supporting mods are fine, might want something for cooling, like a heat exchanger as well. you might also want to consider a lower crank pulley depending on the boost level. One of my friends made well into the 800's on e-85 and a 2.8. obviously on big boost levels.
Old Jan 29, 2008 | 02:00 PM
redeye's Avatar
redeye
I ♥ Acer
personally i would not use 'that' tuner .jmo!
your going to need a sct #2400 also
Old Jan 29, 2008 | 07:11 PM
Blownsvt's Avatar
Blownsvt
or a mafia either way
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
p51pony
Dec 2, 2015 10:02 PM
MasterLanMan
Sep 26, 2015 10:03 AM
hookergt
Sep 4, 2015 06:57 AM
DOHC330MustanGT
Sep 13, 2004 02:54 PM
