SVT Forums
Tires
Old Feb 3, 2008 | 02:22 AM
soldierstang04's Avatar
soldierstang04
Default Tires
I have the stock rims and i need some new tires! BAD! Im loosing to cars i shouldnt b/c im just spinning and slidding and spinning some more. I want a lil bit wider tire in the back than the 275 so i was thinking a 295 but i dont know what size matches up with the 275 that i would have in the front? i want a DR for the back any help guys?
Old Feb 3, 2008 | 10:09 AM
97targa's Avatar
97targa
Default RE: Tires
265/45/17 for up front will match to 295/40/17 I wouldn't go any wider than 295 on stock rims
Old Feb 3, 2008 | 10:25 AM
Be Rad 13's Avatar
Be Rad 13
Default RE: Tires
Wider tires don't actually improve traction and reduce wheel spinning, but rather, they're better for handling and cornering. As a result, if you're looking to gain traction, it's probably better to not go with the widest wheels you can find. Instead, find a wheel with a high stickiness rating.
Old Feb 3, 2008 | 12:40 PM
97targa's Avatar
97targa
Default RE: Tires
ORIGINAL: Be Rad 13
What are you talking about?? Wider tires improve traction. There's more rubber on the ground. Plain and simple. Now a 315/35 tire on a 8" rim will not improve traction because it will be rounded out because it's being squeezed on the bead area. Wider tires don't improve handling. They actually hurt handling. If you knew anything about autocrossing, most guys use 245/45/17's. Max size of 275/40/17. You will never see anything wider on a mustang! They are paired in sizes, never staggered either.
This guy wants DR's which will be much improved over any street tire. DR's suck on handling too as they are soft sidewalled
Old Feb 3, 2008 | 12:43 PM
Ehmark's Avatar
Ehmark
Default RE: Tires
Wider wheels would give better traction but wheels and tires arent cheap.Just get Better tires.
Old Feb 3, 2008 | 01:03 PM
Blownsvt's Avatar
Blownsvt
Default RE: Tires
you can put a 315 nitto DR on the stock rim
Old Feb 3, 2008 | 07:54 PM
soldierstang04
Default RE: Tires
Yeah i want a 295 on the back ina DR but not anything bigger maybe a 305 but thats it. I want the back to look the same as the front which are the stock size. I have the 17x9 10th ann. rims.
Old Feb 4, 2008 | 08:19 AM
Blownsvt's Avatar
Blownsvt
Default RE: Tires
i have the smae rims as you, most peole like the way the 315 nittos looks on them, meaty but not bulging over the edge. i also have stock width tires up front.keep in mind the nittos run narrower than other tires for some reason.
Old Feb 4, 2008 | 08:58 AM
baino's Avatar
baino
Default RE: Tires
Might sound like a dumb question, but is it worth it to go with wider direction treads on the back even though you won't be able to rotate them?
Old Feb 4, 2008 | 02:31 PM
xx9gt6xx's Avatar
xx9gt6xx
Default RE: Tires
If you put anything bigger than a 275 on a stock tire it'll wear funny. Even w/ my 275's set at the proper pressure on my stock wheels the middles of my rear tires were wearing out faster than the outsides. So I have to set them to like 24 PSI, now they wear fine. Get a 275 Mickey Thompson DR and call it a day.Those things are like glue when they're warmed up!
