SVT Forums
slight engine rattle
Old Feb 7, 2008 | 07:43 AM
Blackvenom01's Avatar
Blackvenom01
Default slight engine rattle
I have a 01 cobra wit 48,000 miles when i first got it i did not notice this noice but when i get up to right about 3000 RPM there is a slight rattle just right there at that rpm. I thought that it might be one of my cats like a plate fell loose cause i had that same thing on my old mustang which was a 2003. I ended up gettin a bassani O/R x pipe and i still have the rattle. It only rattles when the car is warmed up. I am thinkin there might be some loose part and that that rpm and engine sound its just enough to rattle it. But i also have no clue wut it could be. If anyone knows of anything or any suggestions or it has happened to u before i would greatly appriciate a comment. thanks
Old Feb 7, 2008 | 12:22 PM
Ehmark's Avatar
Ehmark
Default RE: slight engine rattle
Thats what my engine is doing in my case it is my motormounts there is almost no rubber left in the mount. I am going to try and change them out today with the engine still in the car. Ill tell you if this ends up being the only problem.
Old Feb 7, 2008 | 12:27 PM
Blackvenom01
ok thanks man im bout to go look at mine and see if there worn down too...let me kno how it goes
Old Feb 7, 2008 | 05:58 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
can you get an audio file of the noise, there is to many parts that could rattle. could be the mounts, could be a valve, could be a stupid *** bolt.
if you change your motor mounts while the engine is still in then please, get a video, i've never been able to change ANY engine mounts with the engine in the car.
Old Feb 7, 2008 | 06:08 PM
Blackvenom01
i would get a vid of it but its not that loud of a noise that i can capture it wit a vid...u sorta need a tuned ear to that specific sound cause the exhuast drownds it out a bit....to me it just sounds like a loose part...
Old Feb 7, 2008 | 06:59 PM
USMCrebel's Avatar
USMCrebel
could it be your PS fluid needs changing? or maybe a header/ manifold bolt loose?
Old Feb 7, 2008 | 07:14 PM
Blackvenom01
i kno i hve a slight leak from the ps but idk why that would only make a noise when i hit 3000 no matter which direction...i just out on my x pipe so that is tight but i will look to see if a manifold bolt is loose to the engine...i figured i would hear air but the rest of the bolt could support it
bjdutch2005
Mar 24, 2017 03:38 AM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
tmdm
Sep 4, 2015 06:45 PM
