SVT Forums
IMRC dilemna
Old Feb 16, 2008 | 07:51 PM
RuffCat's Avatar
RuffCat
Default IMRC dilemna
My plates move freely and are not gunked up but unfortunalety I have to remove the upper intake to replace the module that is bad. Should I keep the plates or dump them and remove the butterflies? Also, I just put this motor in last year and have only driven about 200 miles. I kept my gt harness from the computer to the firewall. Could this be my problem? I tried the cobra wiring from the ecu to the firewall and the car wouldn't start so I just kept the GT harness in there. I have the right CCRM so I assume my module is bad. Please let me know what I should do so this gets done once! No one else on the other forums I'm a member of can tell me what to do. They seem to know squat. Thanks
Old Feb 17, 2008 | 05:50 PM
uberstang1's Avatar
uberstang1
Chupacabra
Default RE: IMRC dilemna
If you are using your GT PCM thats the problem, it cannot open the IMRCs i ran into the same problem, I couldnt get my cobra ECU to work with my swap eiother car would start and shut off after about 15-20 seconds, so i went with the deletes and a tune and everything was golden on my gt ECU.
Old Feb 17, 2008 | 08:20 PM
Ehmark's Avatar
Ehmark
The GT harness from the computer to the firewall does not have the propersetup to use the imrc's. You will also need a cobra ecu with that wiring.You couldRemove the imrcactuator and the butterflies and port match the imrc plates youll be glad you did Or If youwant cobra wiring I have a bunch and it would be cheap pm me if interested.Either way you will either need a reflash or a cobra ecu.
djbigskrilla
Sep 20, 2022 01:04 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
rocket22
Aug 28, 2015 07:08 PM
mattkoly
Sep 5, 2007 02:10 PM
jpnelson1978
Mar 21, 2007 12:01 AM
