SVT Forums
Building IRS
Old Feb 19, 2008 | 08:53 AM
NoRdO's Avatar
NoRdO
Default Building IRS
Is there a good writeup on how to build the IRS on a 99 Cobra? I want to change out the 29 spline axels for 31 spline and get a better differential. What parts are needed to build the IRS? Also, what kind of power can a built IRS hold? I'm looking to twin turbo my cobra and I think the IRS would be the first thing to break.
Old Feb 19, 2008 | 09:40 AM
OzzDOA's Avatar
OzzDOA
Default RE: Building IRS
The IRS bible is over at SVTPerformance.com in a sticky in the NewEdge section. A built IRS is actually cheaper and better performing than a SRA.
Old Feb 19, 2008 | 10:10 AM
ponysnake99's Avatar
ponysnake99
http://www.svtperformance.com/forums...d.php?t=231900
^^there you go
basically bushings, girdles and half-shafts. polyurethane subframe bushings, polyurethane UCA/LCA bushings, differential girdle, solid/poly differential bushings, solid differential mount, thicker tie rods or bumpsteer kit, level 1,2 or 5 halfshafts, springs/shocks or coil-overs. in the 99 cobras case, a new differential. other options include shms shepherical spindle upgrade, finding kenny brown UCAs/LCAs, thicker 03-04 pinion flanges (need a shorterdriveshaft) or mods such as these done to the carrier:
http://www.mustang50magazine.com/tec...ion/index.html
Old Feb 19, 2008 | 11:25 AM
Blownsvt's Avatar
Blownsvt
just swap in the irs out of an 03-04, might be easier but i don't know.
Old Feb 19, 2008 | 11:43 AM
NoRdO's Avatar
NoRdO
Thanks for the repilys. thats a great site.
Old Feb 20, 2008 | 02:04 PM
Ellik's Avatar
Ellik
ORIGINAL: Blownsvt
swapping an entire IRS is as simple as dropping exhaust pipes, disconnecting brakes and driveshaft and pulling 4 bolts.
A STOCK IRS out of an 03/04 is only going to be marginally stronger and WILL NOT be the end-all solution to a high-horsepower application.
Old Feb 20, 2008 | 05:59 PM
Blownsvt's Avatar
Blownsvt
isn't the 03/04 irs pretty close the the stuff he was describing, did not sound to me like the op was really talking about going all out on it.
Old Feb 20, 2008 | 07:51 PM
AZ SNAKE's Avatar
AZ SNAKE
Solid Axle FTW........
Old Feb 20, 2008 | 08:08 PM
Blownsvt's Avatar
Blownsvt
thats what i got, i have a complete 03-04 IRS including drive shaft to sell now though.
Old Feb 21, 2008 | 08:14 AM
Ellik's Avatar
Ellik
he was talking about going twin turbo. Thats fairly all-out in my book.... more than what I would trust a stock 03/04 IRS with. just because it came out of a Terminator doesnt mean its indestructible.
Solid axle IS cheaper to built to handle more horsepower.
